My Precious... Precious Ring....
Posted: Wed Nov 14, 2007 5:41 pm
I'm installing a set of Wiseco pistons and rings in my refreshed/cleaned/honed block *ej22t*
My ring compressor was not in the best shape and my number two pistons upper oil ring got caught *the ring on top of the expander* as I was using my piston hammer to genly send the piston home..
I stopped immediately when the piston stopped advancing and noticed that the end of my ring was sticking out a little.
I pulled piston up and out yelling f**k several times..
It worries me somewhat since at rest, it was bent just slightly. Though, when compressed... it sat fine in the groove, but I was wondering if I should just pop it back out if ANY mis-shaped ring in ANY degree will scar and ruin my cyl-wall.... Or am I okay.
IF I DO need to order a set of rings, how/where do I get them. I got these with a kit and they're 20 thousanths over stock...
