Page 1 of 2
Koyo aluminum radiators kick ass!
Posted: Wed Dec 05, 2007 7:55 am
by SuperRallyRoo
http://www.jazzproparts.com/product_p/r1819.htm
So basically Jake from PIA said these rads kick ass so I bought one when he was sitting right next to me. Showed up at my door promtly. And got its gorgious holds a ton extra water OEM fit is perfect. Makes the TW look like I have a fatty FMIC. And now my shit has a ALL aluminum radiator! woo hoo! Pics when I have time will come. The best part is it can be yours at your door for 216.00 shipped!!!
It is a true turbo style with no fill hole. Fit my 92 touring wagon perfect!
Posted: Wed Dec 05, 2007 5:48 pm
by BXSS
I've been thinking about one of these for my Legacy, did you have any problems with the stock fan clearing the Alt/ps belt?
The one I have on my Impreza was a PITA to get in & the fan had to be notched a smidge to clear to Alt belt, but it works very well...
Posted: Wed Dec 05, 2007 6:38 pm
by evolutionmovement
Does anyone know if the Impreza one fits the N/A Legacy? The turbo Legacy is too tall and I'd rather not modify the car to fit it.
benefits
Posted: Wed Dec 05, 2007 7:03 pm
by kleinkid
What are the benefits of this larger radiator over the stock radiator?
Re: benefits
Posted: Wed Dec 05, 2007 7:12 pm
by denver_whitest185
kleinkid wrote:What are the benefits of this larger radiator over the stock radiator?
larger water capacity, which increases thermal efficiency of your cooling system. it makes it easier for your engine to run at normal operating temps. however, you don't really need an upgraded radiator unless your making quite a bit more power over stock or racing extensively.
Posted: Wed Dec 05, 2007 8:05 pm
by Adam West
Post some damn pictures. <grin>
Posted: Wed Dec 05, 2007 9:22 pm
The alloy is also nicer than stock brass as there's no electrolytic reaction.
Posted: Wed Dec 05, 2007 10:42 pm
by SuperRallyRoo
i'll get pics from the front when I have time to edit out my plate #
and no clearance issues dropped right in. Its a little fatter then the old one though.
Posted: Thu Dec 06, 2007 2:28 am
now just make yourself a cooling panel too :)
looks nice
Posted: Thu Dec 06, 2007 2:54 am
by ciper
Does it have holes so you can replace the air dam between the radiator and frame for better cooling?
Posted: Thu Dec 06, 2007 3:11 am
by SuperRallyRoo
holes for the airdam between rad and frame... not sure i know what you mean. But I don't think so either way.
Posted: Thu Dec 06, 2007 3:23 am
by ciper
You know, the part that is supposed to go in between the top of the radiator and the support beam. It would essentially be underneath the mounting brackets that the hood support clips into.
In your picture there is a gap. A part exists to fill that gap so air cannot escape over the radiator and through the engine bay.
Posted: Thu Dec 06, 2007 5:04 am
by Adam West
I'd like a full frontal shot when you have one...
Pretty darn cool, ...note to self...I want this!
Posted: Thu Dec 06, 2007 6:12 am
ciper - That part is only on pre-facelift models, I think.
Posted: Thu Dec 06, 2007 8:31 am
by beatersubi
Does anyone know if Koyo has an equivilant part that'll work for those running a turbo motor in an n/a chassis (where a turbo rad won't fit without welding in tabs)?
Posted: Thu Dec 06, 2007 9:49 am
vrg3 wrote:ciper - That part is only on pre-facelift models, I think.
you can make your own pretty easily. thats what i was talking about earlier in the thread.
http://www.wrxfanatics.com/index.php?showtopic=48942
Posted: Thu Dec 06, 2007 10:04 am
by ciper
Isnt that always the case! Everything good is always on the prefacelift models, especially the Japan built ones (like little white dots on the heater vent controls)
beatersubi wrote:Does anyone know if Koyo has an equivilant part that'll work for those running a turbo motor in an n/a chassis (where a turbo rad won't fit without welding in tabs)?
I was thinking the same thing and thats why I started this thread
http://bbs.legacycentral.org/viewtopic.php?t=33935
Posted: Thu Dec 06, 2007 2:52 pm
ciper - 'Cept headlights that let you see and turn signals that are visible from the side...
Posted: Thu Dec 06, 2007 3:23 pm
by ciper
I like the older style of headlights, fog and all ;)
You got me on the turn signals though.
For a preface lift model my preference is to make the side marker and turn signal be always on and blink off when the signal is going.
Posted: Thu Dec 06, 2007 4:18 pm
by dropdfocus
Great, yet another item to add to my ever growing parts list... :D
Posted: Fri Dec 07, 2007 7:42 am
by SemperGuard
The shroud is only on 90's.
Posted: Fri Dec 07, 2007 10:28 am
by ciper
Semperguard: I think its more specific than that - the shroud might only be on the japanese built Legacys (which many of the 90s were).
From my own experience Indiana built cars are missing the part.
Koyo radiator for SS back order at mfg.
Posted: Thu Jan 03, 2008 8:27 pm
by kleinkid
Koyo radiators for the Legacy SS are on back order at Koyo. About 3 weeks. Seems to be a little rush on them right now.
Posted: Thu Jan 03, 2008 8:31 pm
by dropdfocus
Is that direct or through a distributor?
Posted: Thu Jan 03, 2008 8:57 pm
by BXSS
With those prices I can see why there is a back-order.
My Impreza KOYO does a really good job of keeping things cool - too good in fact with 70mph winter cruise temps dropping down to 128-132*.
I'm ready to go ghetto & put a piece of carboard over a section of it.
