Page 1 of 2
				94 Legacy part out
				Posted: Wed Dec 05, 2007 6:25 pm
				by Freepistol
				I have the turbo and pipes.
Alternator and starter.
New front strut in the trunk and the other new one on the drivers side front that can be removed.
I have pending deals for the transmission and rear sway bar assembly.
Windshield, fenders, front bumper, sun roof---no good.
Most everything else there except the engine.
I do have the grille pictured farther down the thread.
Ben
Berwick, Pa 18603
				Posted: Wed Dec 05, 2007 7:32 pm
				If you can get the ABS sensor out of the front driver side hub (the sensor pickup, not the toothed ring), I'd like to buy it.
scuzzy might be interested in the turbo pipes.
				Posted: Wed Dec 05, 2007 7:35 pm
				by denver_whitest185
				i sent you a pm about the boost control solenoid
-Ted
				Posted: Wed Dec 05, 2007 8:54 pm
				by jamal
				Left rear turn signal to 90220?
				Posted: Wed Dec 05, 2007 11:40 pm
				by Freepistol
				vrg3 wrote:If you can get the ABS sensor out of the front driver side hub (the sensor pickup, not the toothed ring), I'd like to buy it.
I should be able to get that for you. I need a couple of days because the car is outside in the snow storm right now.
Ben
				Posted: Wed Dec 05, 2007 11:44 pm
				Okay, whenever you're ready... I've been looking for one of these sensors for years. It can be hard to get them out of the hub without bending/breaking them.
				Posted: Wed Dec 05, 2007 11:57 pm
				by Freepistol
				jamal wrote:Left rear turn signal to 90220?
Hi Jarnal,
Driver's side rear turn signal looks good. Is it just the lens you need or does it come as one unit with the light holder?
Ben
				Posted: Thu Dec 06, 2007 1:13 am
				by ciper
				ECU and Harness still intact? MAF and intake piping still available? Any parts from above the engine left? (intake parts, injectors)
Does anyone know how heavy the factory downpipe is?
				Posted: Thu Dec 06, 2007 1:41 am
				by jamal
				Freepistol wrote:jamal wrote:Left rear turn signal to 90220?
Hi Jarnal,
Ben
I don't think they come apart. If they do then the lens is all I'd need.
				Posted: Thu Dec 06, 2007 1:45 am
				by Freepistol
				ciper wrote:ECU and Harness still intact? MAF and intake piping still available? Any parts from above the engine left? (intake parts, injectors)
Hi Ciper,
ECU is still in the car. I removed the engine so nothing was cut. Intake and injectors are still on the engine. I am going to rebuild it and stick it in an airplane so I won't be using any of that. Tell me what you want and make an offer.
Thanks!
Ben
				Posted: Thu Dec 06, 2007 5:02 am
				by scuzzy
				I need your air bypass valve if you still have it, and I could probably use your intake pieces pre and post turbo just because I can cut on them.
what say you?
				Posted: Thu Dec 06, 2007 5:23 am
				by greg donovan
				vrg3 wrote:Okay, whenever you're ready... I've been looking for one of these sensors for years. It can be hard to get them out of the hub without bending/breaking them.
i broke 4.
				Posted: Thu Dec 06, 2007 11:27 pm
				by gaugedk
				I need your Pressure Sensor.
				Posted: Thu Dec 06, 2007 11:44 pm
				by Trace
				Is it a non-turbo or a turbo?
I'm looking for a front bumper cover and the front steel reinforcement of a turbo model.
thanks.
				Posted: Fri Dec 07, 2007 3:12 am
				by Freepistol
				gaugedk wrote:I need your Pressure Sensor.
Hi gaugedk,
Please give me a couple of days, I have some unexpected business that needs to get done right now.
Thanks!
Ben
				Posted: Fri Dec 07, 2007 5:04 am
				by gaugedk
				No problem
				Car in garage and found the grille
				Posted: Mon Dec 17, 2007 3:36 am
				by Freepistol
				I found the grille in the trunk! Nothing appears to be broken. I'm not sure what the bottom grille is in the picture, but it is for sale, too. The grey one isn't as nice because of the faded paint.
The unknown grille has all of the plastic pins broken on the bottom row.
I will take more pictures of either one if you are interested.
I have the car in the garage to get all the parts that were requested. If anything else is needed, please let me know.
Thanks!
Ben
				Posted: Mon Dec 17, 2007 10:19 pm
				by Freepistol
				jamal wrote:Freepistol wrote:jamal wrote:Left rear turn signal to 90220?
Hi Jarnal,
Ben
Hi Jamal,
I have the turn signal unit for you. The bulb plate comes apart from the lens. Do you still need it?
Ben
				Posted: Tue Dec 18, 2007 4:14 pm
				by pankopp
				hey do you still have the adjuster that is used to adjust the Alt. up and down to tighten the belt>? I need the part that you tighten or loosen to move the whole assembly up and down.  Mine has a broken bolt in it that will not come out.
Let me know!
				Posted: Tue Dec 18, 2007 5:21 pm
				by Freepistol
				pankopp wrote:hey do you still have the adjuster that is used to adjust the Alt. up and down to tighten the belt>? I need the part that you tighten or loosen to move the whole assembly up and down.  Mine has a broken bolt in it that will not come out.
Let me know!
Yep, I have that.
What's your zip code?
I'm 18603.
Ben
				Posted: Thu Dec 20, 2007 3:44 am
				by Tim Catton
				Is the instrument cluster still available?  Would you be willing to ship it?
				Posted: Thu Dec 20, 2007 3:51 am
				by Freepistol
				Tim Catton wrote:Is the instrument cluster still available?  Would you be willing to ship it?
Hi Tim,
Yes, the cluster is still in the car and I will ship it. Tell me what all you need and how much you think it is worth.
Thanks!
Ben
				Posted: Thu Dec 20, 2007 5:18 am
				by Tim Catton
				I sent you a pm on the instrument cluster
				Posted: Thu Dec 20, 2007 4:46 pm
				by dropdfocus
				Automatic or manual?  If maunal, interested in the tranny & full pedal assembly.
Also interested in the stock trunk spoiler.
BTW, I can pick up the parts since I'm only like 30-35 miles away.
				Posted: Sat Dec 22, 2007 9:52 pm
				by Freepistol
				dropdfocus wrote:Automatic or manual?  If maunal, interested in the tranny & full pedal assembly.
Oh yeah, I forgot to say I have the spoiler, too.
Ben
