Page 1 of 2
Differences between NA / Turbo radiator (beside filler cap)?
Posted: Thu Dec 06, 2007 1:43 am
by ciper
My memory fails me but I swear I remember that one of the radiators was taller and because of this the "frame" below it was different. Who can clarify with measurements and such?
Posted: Thu Dec 06, 2007 2:12 am
by thehookeup
im pretty sure they are nearly the same, other than the cap in a different spot. they have the tranny oil cooler
Posted: Thu Dec 06, 2007 2:32 am
by evolutionmovement
I don't recall measuring the difference in lower mounting heights on my parts turbo and the N/A wagon (and the parts car is long gone), but the turbo radiator is 17.25" and the N/A 16" tall. The hood on my N/A won't come close to closing with the turbo radiator.
The tranny cooler is only on the autos.
Posted: Thu Dec 06, 2007 2:50 am
by ciper
That is good to know.
What is needed to modify an NA body to fit a turbo radiator? I assume it is only the lower mount but isnt this part welded/painted to the car? I'm very interested in the koyo radiator someone recently reviewed.
I am sick and tired of the crap OE radiator end tanks cracking. I'd bet that more Legacys die of cracked radiators than any other cause (including accidents)
Posted: Thu Dec 06, 2007 3:08 am
Yeah, my replacement N/A is only 4 years old and crumbling so I don't want to trust it with the turbo, but the turbo radiator I have won't fit, so that's one reason the car's been sitting for a couple years.
There's a double-skin lower mount welded in place, which is why I'm reluctant to modify it. Any time you cut metal up here, you're looking for corrosion issues. Looks like there's only about a half inch to gain anyway by removing the upper skin.
That's why I was wondering if the Impreza one fits, possibly being shorter than the turbo Legacy.
Posted: Thu Dec 06, 2007 3:22 am
by ciper
I bet we could contact the manufacturer of it (or a similar unit) and get the specifications. I have only found one all metal radiator for the NA Legacy and it was a little too soft for my liking. I almost broke the filler neck clean off the first time I replaced the cap.
Posted: Thu Dec 06, 2007 6:02 am
Are the NA and turbo chassis different in every model year, or just in 1990 or just in 1990 and 1991?
Posted: Thu Dec 06, 2007 7:48 am
by bmxpunk
My impression while looking for myself a KOYO was the turbo legs and the GC impreza were the same. I am really interested now, since that is the next item on the shopping list
Posted: Thu Dec 06, 2007 9:22 am
by GLCraigGT
Posted: Fri Dec 07, 2007 1:50 am
by SemperGuard
vrg3 wrote:Are the NA and turbo chassis different in every model year, or just in 1990 or just in 1990 and 1991?
All of the NA Legacys have the same size radiators, and same space from bottom to top in the chassis, and all the turbos have larger radiators, and larger space.
Posted: Fri Dec 07, 2007 3:17 am
by livestrong14
So people who have swapped to a Turbo engine in a non-turbo legacy can't use Turbo radiators? Can the N/A radiators handle that task?
Posted: Fri Dec 07, 2007 3:37 am
by 555BCTurbo
livestrong14 wrote:So people who have swapped to a Turbo engine in a non-turbo legacy can't use Turbo radiators? Can the N/A radiators handle that task?
No, they can...Jake Talbot (Jake15) knows how to modify the radiator to make it fit in a NA chassis (as his began life NA)...NA Radiators can handle the task to an extent, but from what I have seen, they tend to run a wee bit hotter.
Posted: Fri Dec 07, 2007 4:15 am
by livestrong14
How do you go about modifying it? What has to be done?
Posted: Fri Dec 07, 2007 4:29 am
by ciper
I dont think the radiator was modified. I cant see how you can make it an inch shorter
Posted: Fri Dec 07, 2007 5:38 am
Thanks, SemperGuard. I was wondering if it was a 1990 thing because the only evidence I heard of before was from 1990 models, which just happens to be the one year that there was no turbo model.
Posted: Fri Dec 07, 2007 7:44 am
by SemperGuard
You have to cut and weld the lower radiator support. As was said, the NA radiator is fine to an extent. Track it and it overheats.
Posted: Fri Dec 07, 2007 3:03 pm
So do the N/A Imprezas have the same size as the turbo Legacy's? Would seem to make sense, I guess, as the shell was used for the Impreza turbo/WRX.
Posted: Fri Dec 07, 2007 4:41 pm
by SemperGuard
No, only 90-99 NA legacys have the small radiator, and small size. But it's not all bad. I have an idea that I want to confirm 100% before I post anything. Impreza, Forester, 00+ Leg/BAJA all have larger rad and size.
Re: Differences between NA / Turbo radiator (beside filler c
Posted: Sun Nov 06, 2016 7:20 pm
by nortonjefferson
Bump from the dead, does anyone have photos of how they modified their NA crossmember to fit a turbo radiator? I have a means of fabricating and cutting but id like to see how others have done it (if they have) before I buy a turbo rad and commit to cutting stuff up. Thanks!
Posted: Mon Nov 07, 2016 6:59 pm
I know there is a small handful of people that have modified the lower radiator support so hopefully they took pictures and can chime in. However, as I understand it, the entire lower core support is just lower. The turbo support's bends that attach to the chassis are longer so the horizontal part of the core support sits lower to accommodate the taller radiator.
Posted: Sat Nov 12, 2016 6:08 am
by impostor
Here's my story for informational purposes. I have a 95 Impreza with an EJ22t swap done by me in 2003. I installed the correct legacy turbo radiator, and it fit like crap. It was too big so I angled it back slightly at the bottom which also made the fans come within about a quater inch of the front engine accessories. A year ago the LH tank cracked. I went through our inventory or radiators at the shop and noticed how the 04-08 FXT aluminum Koyo radiator had everything in the right places. Almost fits like a glove. I did have to buy the FXT style upper support brackets. I used an FXT cooling fan shroud and blades, and legacy fan motors. I have an engine bay shot in my "AWIC folks..." thread.
Sooo, based on what you guys are saying, it sounds to me like the n/a legacy and n/a impreza are closer in dimensions.
Posted: Sat Nov 12, 2016 6:52 pm
by rallyak
If you need to buy a new radiator anyway I would look in to a gt radiator with a thicker core, it fits the n/a opening and has more cooling. I have a new oem one going in my car when I do the motor swap.
Posted: Mon Nov 14, 2016 6:29 pm
Posted: Mon Nov 14, 2016 8:19 pm
by nortonjefferson
Thankyou everyone for your input/suggestions! Looks like I'll be opting for the gt radiator, Josh is spectra the brand of radiator you're running? Or just oem? If spectra have you had any issues in the long term with it? i think I'll just spring for a 96-97 gt spectra model! Thanks again everyone, I know this has been covered a lot lol.
EDIT: I ordered up the spectra legacy gt radiator. $102 with tax and free shipping from amazon. For anyone referencing this for info the SPECTRA part number is "CU2082"
Posted: Tue Nov 15, 2016 6:09 pm
I ended up getting a Subaru OEM GT radiator.
Let us know how the Spectra radiator is and if you don't mind sharing some pictures that would be great.
