So I just wanna be real clear here...
Posted: Thu Dec 20, 2007 7:09 am
by Arctic Assassian
As long as I get the full takeoff assy. from a 2003 wrx sedan, I can have everything I need to put it all on my 1991 SS?
-Adam
Posted: Fri Dec 21, 2007 2:43 am
by 555BCTurbo
You will need different rear tophats...the WRX ones don't work
Other than that you should be golden
Posted: Fri Dec 21, 2007 2:45 am
by boro
I have always want to strip the underside of a WRX for this reason. Good luck with everything. He is correct, you need to change top hats to Legacy ones.
Posted: Fri Dec 21, 2007 8:21 pm
by smh0101
Yup... I have this set-up... Ya need the rear Legacy Top-Hats...
BTW I love this setup... I have 03 WRX KYB GR2s and WRX OEM springs.
Raised the car about an inch... Good for snow... Yet handles great... IMO
Posted: Fri Dec 21, 2007 8:30 pm
Won't you also need camber bolts for the rear? With my STi v7 suspension I did, since without them I couldn't achieve negative camber.
Posted: Fri Dec 21, 2007 8:35 pm
by smh0101
Ah... Yes Vikash... You are correct (Big Shock :lol:)
I did have camber bolts installed on the rear... Schwab gave me a helluva lotta negative camber...
Before:
_____
After:
_____
Posted: Fri Dec 28, 2007 2:01 am
by Arctic Assassian
Thanks guys.
