@#$@#$*FSDF Oil leaks!
Posted: Sun Dec 23, 2007 12:59 am
Thought I was done with the engine, apparently not.
So. I replaced the rear main seal when the engine was out; but I cannot seem to get the new one installed without tearing at least a little piece off of it (like I did the last one) I figured if I used high-temp red RTV and really packed it on there, job would be done; no leaks.
Guess not. I noticed a little oil on the jack plate when the car was at the muffler shop, I thought maybe I didn't tighten my power steering lines enough. I got home, left a piece of big cardboard under the car/engine overnight and came back in the morning to find a pretty big spot of oil; about the size of a dollar bill folded in half lengthwise.
From the smell of it; it did not have a typical oil smell; so I passed it off at just... long story short
Fired the car up to clean the garage, pulled the car out of the garage (wasn't warmed up yet, had been idling maybe 30 seconds but I didn't touch the throttle at all). parked it on my driveway that slopes down hill towards the garage (nose is lower than tail) cut it off just about immediately.
30 minutes later, there's a spot of oil on the ground the size of a dollar bill. I freaked, pissed. smelled the oil, smells like oil. smelled the power steering fluid (ATF) doesn't smell anything like ATF, knew it was oil. looked at the crossmember and I could see where it was coming down, rear of the engine.
couldn't possibly be my fucking rear main seal again! seems like a never ending saga.
I run 5W30 dyno oil, the spot was bigger with the nose of the car pointing downwards which doesn't make much sense - oil would be flowing away from the rear of the oil pan and from the rear of the main seal; it's not as if either of these are under much pressure.
Do you figure it could be the front seal on the transmission maybe? Any thoughts are appreciated. The baffle plate and all that mess were fine when I pulled the engine out, no visible oil spots at all.
edit: no, can't be. gear oil smells nothing like engine oil (at least in my car). Meh, tired of chasing down this goddamn problem. Guess I didn't spend enough time on it when I did the oil seal last time.
Does anyone have a better idea about the oil seal? the best I could come up with was to spray it in lithium grease and hammer it in slowly with a wooden dowel, just like I did the previous time (and still tore the freaking seal)
I can't push it in by hand, it's too hard, doesn't seem to fit.
