Smoke - will the car go for 3 more months?
Posted: Fri Dec 28, 2007 8:33 pm
by nicebloke
My 1990 N/A MT wagon (215,000 miles) has started to puff blue smoke. It only happens when I get it up over 4000rpm, and only for the first minute or so after sitting overnight. I'm thinking valve seals...
Performance is not affected.
Question is this: I just got a new job that pays much better and am going to get an STI in three months (after I pay off my new motorcycle
) Will I be okay driving the Leggy on occasional journeys until then? I don't commute with it, and drive it maybe 3 times per week around town.
When I get the STI, will the Legacy pass CA smog (it passed last time)? I'm guessing that valve seal blowby has a negligible effect on emissions once the car is nice and warm...
Posted: Fri Dec 28, 2007 8:48 pm
by Arctic Assassian
Well, If you keep brapping it out to 4000rpm right when you start it up, I'd be surprised if it lasted a week. Why the hell are you doing this? You start a car, sit in it for about thirty seconds, then drive slowly untill it has warmed to temp. Unburned oil has lots of hydrocarbons in it. I doubt it will pass.
I hope you get your new sti and treat it the same way, let me know when you blow your turbo, or a ringland.
Posted: Fri Dec 28, 2007 9:50 pm
by ericem
The blue smoke might be a cheap paper air filter. Try changing the PCV valve.
Posted: Fri Dec 28, 2007 10:41 pm
by tris91ricer
and try changing the oil! I'm telling you, sometimes it's the little things. . .
Posted: Fri Dec 28, 2007 11:24 pm
by Matt Monson
It's an Ej22! As long as there is still oil in the pan, of course it will run for another 3 months. I can't believe this question is even being asked...
Posted: Sat Dec 29, 2007 12:01 am
by ericem
Not even. As long as there is gas in the tank and a working fuel pump and power source to the ECU and fuel pump and the starter when you start it. NOTHING can stop it then! XD
Posted: Sat Dec 29, 2007 2:54 am
by evolutionmovement
Yeah, even blowing oil all the time you'd be fine unless it was an exhaust valve, then you'd only have a hundred miles or so and you'd be using a quart of oil every day or so.
Posted: Sat Dec 29, 2007 4:58 am
by twentz90
mine has over 260k and I swear I could put a brick on the gas pedal to blow it up and it wouldn't blow. As long as you change the oil and keep a check it will make it for a long time which someone apparently hasnt been doing
Posted: Sat Dec 29, 2007 6:21 am
by nicebloke
Arctic Assassian wrote:Well, If you keep brapping it out to 4000rpm right when you start it up, I'd be surprised if it lasted a week. Why the hell are you doing this?
I'm not.
The car was sluggish starting, which later turned out to be a battery that needed replacing. As I was trying to figure out what it was I gave it some gas and noticed a slight puff of smoke in the mirror. So I gave it more gas, and found the symptom I mentioned. I tried again this morning and got the same result. That's twice.
I came here for a little advice, not to be treated like a fool. I'm sure you meant well, but it didn't come across that way.
