Too Cold.
Posted: Fri Jan 04, 2008 4:07 am
by courtjesterclown
I've been noticing here that after driving on the freeway for any amount of time that my temp. gauge will drop down all the way to cold, but will eventually climb back up to half way. only to drop back down to cold shortly. I kno this cant be good for the motor to run this cold. Any chance that this might jus be a faulty gauge? BEcause my heater and vents still blow pretty warm air. IF not, should i try replacing the thermostat?
Posted: Fri Jan 04, 2008 4:09 am
by Arctic Assassian
You might have a thermostat that opens too cold. Also you may have a bad gauge. I have seen multiple ford explorers do this.
Posted: Fri Jan 04, 2008 4:38 am
by ericem
I would replace the gauge sensor first, then see if it works fine. Then if it doesn't try the thermostat. With my car I ended up changing my thermostat for no reason when it was just my gauge sensor.
Posted: Fri Jan 04, 2008 6:59 pm
If you do replace the t-stat, make sure to replace it with a subaru t-stat.
