adjusting waste gate
dirtyhandssubaru555
Post by dirtyhandssubaru555 »
im not sure if i have the was gate adjusted right. what would be the correct way to adjust it? it should be open at an idle right?
my girlfriend finaly found out that i spent more money and time on my car then her. she was kind pist to say the least.
92ss, tdo4, wrx stage 1 clutch and 9.5 pound flywheel, sti springs, k&n panel filter, desnorkus
86 gl hatchback rip
87 gl10 rip
Arctic Assassian
Post by Arctic Assassian »
I think it's closed at idle... because the actuator doesn't run off vacuum, its is opened by pressure, and at idle there is lots of vacuum.
Kickin' it old-school.
Yeah....it shouldn't be open at idle. And you really shouldn't have to adjust anything. Maybe put a little bit of tension to make sure it's closed
dirtyhandssubaru555
ok i got things right. i have some tension on the actuator, but im not sure how much would be good, what would happen if i had to much? besides that fact that it wouldn't open. higher boost? damage?
86 gl hatchback rip
87 gl10 rip
Get a little hand pump and see how much pressure it takes to open. If you get it up to your target boost and the wastegate hasn't even moved yet, you'll overboost.
If it doesn't open, you'll overboost, and all kinds of damage associated with overboost can happen. If you haven't messed with the ECU's control, it should cut fuel if you overboost above about 13 psi for more than about 3 seconds, so that would be a last-resort failsafe.
mgroshong
Post by mgroshong »
can i use a bike tire pump running to the wastegate? then have a boost guage tee'd off the hose to the wastegate to test if my wastegate is sticing shut?
cars:
- 1991 legacy SS, stock
- 2003 s2000, turbo project
- 1991 crx dx RHD
- 1990 probe gt, 12 lbs, lowered
Yes, if you can work the plumbing out.
I've never heard of a wastegate sticking.
You could check if it's stuck shut by unbolting the rod and trying to open the flapper; it should open easily. Or just push the rod by hand; it'll take a lot of effort but you should be able to get it to move.
mgroshong
Post by mgroshong »
well i hit fuel cut while part throttle driving the other day out of no where.... and i'm still having problems with it creeping up on me
cars:
- 1991 crx dx RHD
sublunacy
Post by sublunacy »
sorry to hijack
i want to add ive had many usuall legacy problems
and im getting them sorted anyway my wastegate deffinately
WAS stuck shut untill 2 weeks ago.... but cause my turbo is done
for it doesn't get use much I guess, anyway I got REAL frustrated
cause liquid wrench did nothing when i torqued it so i torqued ti harder and it came loose, now its smooth opperator
Turbo still sucks thou
"Hows the transition look?"
91 turbo manual
BMX in the trunk!!!
