Who Is Running a dtec?
Posted: Sun Jan 27, 2008 1:57 am
by Ej22TIM
how do you like it? what is required for an install?
I know you need a GBA, but do you need to buy a special wiring harness? will it even work with my turbo legacy ecu?
sorry about all the NOOB qs.....
this seems like the best piggyback out there in my opinion
Posted: Mon Jan 28, 2008 4:35 am
by beatersubi
I posted a thread asking the same question not too long ago. It seemed like a few members were planning on using this and one that had lost his car to a wreck, but I couldn't get much current info on the thing.
Just to let you know, it doesn't directly control timing. Which is the reason I discluded it in my search for EM.
For a piggyback, have you looked into the PerfectPower from RalliTEK?
Posted: Thu Jun 12, 2008 3:18 am
by Ej22TIM
bump
I recieved my dtec the other day in the mail and I am starting to install it, can anyone tell me any tricks to the install?
Posted: Fri Jun 20, 2008 11:30 pm
by Ej22TIM
BUMP
Posted: Sat Jun 28, 2008 9:38 pm
by Ej22TIM
so nobody is running a dtec? I guess ill be the first then?
Posted: Wed Sep 10, 2008 3:33 pm
by westy2005
I have one I just removed from a parts car, and I am installing it on a friends 91 SS with EVO3 16G and large injectors, this is the same setup the parts car had. Parts car made ~320whp on this setup, no knock and a fair amount of timing. LMK if you need anyhelp, as I will be documenting the install of the DTEC/Knocklite.
