Good Cluster with bad Speedo
internetautomart
Post by internetautomart »
135kish miles
from an A/T ABS AWD N/A
only issue was the speedo read fast, the odometer and all other gauges work fine.
Make me an offer!!
next stop is egay for it, along with some other misc car crap (non-subie)
94 BC w/ AWD Sold 6/25/08
92 BJ Rust bucket gone
90 BC (I think) Stripper, gone since 2k
86 GL10 Turbo 4wd, Gone since 99
Blackbart
Vendor
Vendor
Post by Blackbart »
Are you sure the speedometer isn't off due to tire size?
I swapped some WRX wheels/tires onto my wife's Outback and the speedometer is now off by 10%. I was curious as to how much the tires would change things so when I was on the highway I clicked my odometer at a mile marker, drove 10 miles and my odometer said I went 11 miles. So I can assume that if I am driving 70mph the speedo will read 77mph.
But if your odometer is reading correctly then I guess your speedo really is broken.
internetautomart
100% positive.
I swapped in the cluster I got from you and it's all good now.
Besides, this car is bone stock other than the radio.
