i was told that sohc 2.5 heads will bolt straight on to an NA ej22 block i was wondering how true this is and if my old intake and exhaust manifolds and wiring will bolt up if not what has to be done and also wich head gasket do i use ej22/ej25 if there at all different
thanks
Ej25 sohc heads on NA ej22
scoobydoo12345
the_watts10
