wheel shake
Posted: Mon Feb 11, 2008 8:10 am
by greatjorb88
Does anyone have a common explanation for my steering wheel to be shaking at over 55mph? It's weird, it's totally fine until you go past around 55 and then it starts to shake worse and worse the faster I go. Is my alignment bad? Is it possible for a bad road to throw that off? Cause ours is hideous, it's complete slush. Thanks.
Posted: Mon Feb 11, 2008 11:24 am
by asc_up
A bad alignment can cause that.
You may also need to have your tires/wheels rebalanced.
I also had this problem, so I went into Les Schwab and asked them to torque down my lug nuts. They did that for free and it solved the problem.
Posted: Mon Feb 11, 2008 1:40 pm
by speedoboy31
at 55 and up, i'd be inclined to think axle wear/balance might be an issue. or of course iced up wheels? i'm assuming your front end is all tight and tires have been balanced.
Posted: Mon Feb 11, 2008 11:34 pm
by greatjorb88
Hmm. Yeah they should be. I just recently had a shop (discount tire) switch out my all seasons for studded snows. Is it possible they were lazy and didn't torque my wheels down properly? I'm at work now but that'll be the next thing to check.
