JDM Legacy steering wheel installed
DLC
Post by DLC »
Thanks to SilentRacer, I got to install a new bit of kit on the BE.
(click for gallery)
I followed some great instructions from this Scoobymods thread
The install took about 40 minutes, but a bit more time because there were some steps in the other writeup that were not covered well.
The airbag and the front cover of the wheel are one unit and do not detatch from each other. The two Torx-30 bolts on either side are indeed captured, but they're still tricky and try to keep you from getting the airbag on and off.
The electrical connector is a PITA...without using a screwdriver to pry them apart:
(click for gallery)
Removing the black connector at the bottom rear of the wheel housing is necessary. It just slips out laterally. Apparently JDM cars don't normally have cruise control, so the USDM connector has horn and cruise, not just one wire for the horn. Simple swap.
The horn ground and cruise stalk were easy to remove, using the same Torx-30 and a Phillips screwdriver:
(click for gallery)
The 17mm center mounting bolt was not as tight as I thought it would be. I did have to pull violently on the wheel to get it to come loose. I'm a strong guy, but I was really surprised. I took the ScoobyMods advice and didn't take the nut all the way off, which saved me from getting my teeth knocked out...
Install was pretty much the reverse of removal. Everything slotted in where it needed to be.
Don't be surprised if, like me, you get the steering wheel off by one or two teeth. I had to drive around a bit, adjust it, then drive around more to get it on perfectly centered.
Cruise works, horn works, car turns...success!
I like it. Looks better, grips better and the preforated leather will be nicer in the summer and during spirited driving when that extra level of grip is even more important.
Legacy Central
smh0101
Post by smh0101 »
Very cool!
asc_up
Post by asc_up »
Very nice. It looks great next to your shift knob!!
Do I smell ProDrive?? Haha.
DLC
Post by DLC »
Yeah, that's a black Prodrive knob. Cold!
Legacy Central
asc_up
Post by asc_up »
Hahaha I know how that goes. I have one of the metal knobs with "STi" engraved on it, and man-oh-man is that thing cold in the morning. :roll:
livestrong14
Post by livestrong14 »
Looks perfect! Fits the theme very well!
91 SS -Carbon Bronze Pearl
EJ257/EJ205 Hybrid
93 Ford Ranger-DD
91 Rio Red SS- RallyX Project
93 AWD Sedan- FOR SALE!
Looks good. Is there any difference between that and a USDM bugeye WRX wheel?
DLC
Post by DLC »
The center logo is different on the USDM Bugeye one that ScoobyMods shows.
Click the link up top and check it out. I'd link to the image but it's not working at all right now.
Legacy Central
