Anyone running HID's
Posted: Wed Feb 20, 2008 7:16 pm
by 94TurboWagon
Anyone running HIDs on their 92-94 Legacy Turbo. If so, what kit did you go with and how easy is it to install. I see a lot of plug n play kits on ebay. Which would you suggest.
Posted: Wed Feb 20, 2008 7:21 pm
Don't!
Posted: Wed Feb 20, 2008 7:34 pm
by evolutionmovement
Hella 90mm.
Posted: Wed Feb 20, 2008 11:16 pm
by Arctic Assassian
GE ultrabrights, and hella foglights. Dont do hid's, they blind people unless you hack your housing up to install projector lenses.
Posted: Thu Feb 21, 2008 5:11 am
by Brat4by4
Posted: Thu Feb 21, 2008 7:13 pm
That's a pretty good article...
Posted: Thu Feb 21, 2008 7:31 pm
They also sell the Hella 90mm's.
Posted: Thu Feb 21, 2008 11:28 pm
by Arctic Assassian
he's prolly gonna do it anyways.
Posted: Fri Feb 22, 2008 12:08 am
by DLC
I'm going to put 4300k HIDs in my GT, but there's a very big difference between my headlight arrangement and yours.
The 00+ GT had split bulbs for high/low beams, so the HID bulbs are only getting a normal amount of voltage, so they're not super bright. I queried the previous owner of the set many times and he assures me that it's much better in a split setup than mono-bulb arrangement, like earlier models.
I will keep this stuff in mind though. Good infos.
Posted: Fri Feb 22, 2008 2:19 am
Don't do it, Dave! Don't buy into the hype!
That stuff you say about "only getting a normal amount of voltage" doesn't actually make any sense. And while it's true that the HID hackjobs for single-bulb headlights are worse than the HID hackjobs for dual-bulb headlights, but they're still hackjobs that'll at the very best simply hurt your ability to see.
Posted: Fri Feb 22, 2008 2:21 am
by DLC
Can't do much besides re-sell 'em. I've already paid for them and they're in the mail.
The set I'm getting is from a fellow BE owner who has used them extensively. He says he has problems driving other cars at night now because the lighting is so poor.
I guess we'll see (pun unintentional).
Posted: Fri Feb 22, 2008 2:25 am
Think about this logically. The fact that you've paid for something that'll ruin your lighting doesn't mean you have to ruin your lighting.
Also, realize that thinking you can see better is different from actually seeing better. There are a lot of reasons he thinks he can see better with them, and I've enumerated them in other threads on this topic, but the fact is that he cannot.
Upgrade your lighting circuit, get a set of high-output H1 bulbs like the Narva RangePower +50 Daniel Stern sells, and you'll see way better. I promise.
Posted: Fri Feb 22, 2008 2:27 am
by DLC
FWIW, here's his DIY thread on the installation:
http://www.sl-i.net/FORUM/viewtopic.php?t=4527
I know I can resell them. Guess there's more than one way to learn, right?
Posted: Fri Feb 22, 2008 4:42 am
by smh0101
Oh boy... here we go again...
So Jamal... when ya plannin on jumpin in on this shit?? :wink:
Posted: Fri Feb 22, 2008 5:30 am
The DIY article linked to by DLC wrote:Housings with a single bulb like H4 (honda civic) will cause the HID to receive hi beam voltage and therefore blind traffic.
That makes no sense at all. I don't even know where to begin explaining what's wrong with it.
With non-HID headlights, all filaments get the same voltage -- the voltage of the car's electrical system.
HID capsules run off very high voltage, produced by the ballasts.
Nearly all installations of HID capsules into lamps designed for halogen bulbs will blind traffic. The reason has nothing to do with voltage; it is that an HID capsule and a halogen bulb produce completely different patterns of light.
The same article wrote:Next you will want to upgrade the headlight fuses from 15amps to 25 amps.
GAAHHH! Replacing a fuse with a higher-amp fuse is a definite no-no. Anybody who knows anything about a car's electrical system will tell you that. Unless you like carbeques... And calling it "upgrading?" GAH!
Posted: Fri Feb 22, 2008 5:34 am
by DLC
OK, ok. I guess they're going on eBay.
I did get a set of GT headlights with cleared corners. They're illegal too, but at least they won't affect my lighting...
...or WILL THEY?
Posted: Fri Feb 22, 2008 5:45 am
by smh0101
Okay... I'm gonna get flamed here so bear with me... I'm kinda cold right now :lol:
What if you made a clear acrylic lens, then mounted an HID system behind it within the stock housing with no fluting (or whatever the hell its called) and not silver lining? Of course, the system being from an OEM source, then aiming them correctly?
Posted: Fri Feb 22, 2008 5:47 am
by smh0101
And I mean legality issues aside and purely function.
Posted: Fri Feb 22, 2008 5:48 am
Dave - Hehe... It depends. I've never taken apart a set of GT headlights. If any lenses were removed, then yes. If the only thing removed was a color filter, then no. Unfortunately, if they're like most other lights, then it's the former.
smh0101 - That'd work. That's what Steve's suggesting with the Hella 90mm units.
Posted: Fri Feb 22, 2008 5:50 am
Though I'll add that the halogen Hella 90mms will actually probably allow you to see better than the HID ones.
by smh0101
Oh okay, cool! Thanks V
Posted: Fri Feb 22, 2008 6:16 am
by Brat4by4
Good to be on a forum where Vikash can be there to trump the cause for as-designed lighting. So much pseudo-science subjective crap goes around about these (Oh, but I can definitely see better! - Yet very expensive light sensoring equipment and a century of lighting science tailored to the human eye says your wrong...)
Take one look at that video in the link I posted, which Vikash originally posted long time ago, and see what HID "conversions" do to E-code lights... Ick! That should tell you right there how not-good these things must be - especially if you've ever driven in a car with good stock lighting, like a lot of older BMW's.
Posted: Fri Feb 22, 2008 7:24 pm
Yeah....the link you posted is really quite good. The work done with DOT also shows the light scatter, and how unfocused it is.
