Fuel Gauge Went AWOL...
Posted: Wed Feb 20, 2008 9:58 pm
by asc_up
I was driving last night and I watched my fuel level gauge rise from about 1/4 tank up to full. It pegged itself up there and then the instrument panel light that illuminates it simply shut off.
So now it says I have a full tank of gas and the light behind it blew out or something.
Did the gauge just 'die' or what?
Posted: Wed Feb 20, 2008 10:37 pm
Hmm....that's pretty weird.
You can do some testing to see if it's the gauge or sender units. Unplugging the connector under the rear seat should make the gauge go to empty. Also, you can test to see if the low fuel light comes on.
http://www.main.experiencetherave.com/s ... t_test.jpg
Posted: Wed Feb 20, 2008 10:59 pm
by asc_up
Ok Josh. I tried some of those tests.
When I unplugged the harness, the gauge stayed pegged at full.
I also grounded the #4 pin on it and that did trip the low fuel light.
I'm thinking the gauge screwed itself, because the sending unit seems to be working fine...
Posted: Thu Feb 21, 2008 6:55 pm
Yeah it sounds that way.
Posted: Fri Feb 22, 2008 3:29 am
by asc_up
Hmmm would it be easier to buy a whole new instrument cluster or just the fuel gauge itself?
Posted: Fri Feb 22, 2008 7:19 pm
You can't purchase just a new fuel gauge. You're best off trying to get a used cluster, and swapping over the gauge, or at least taking the old cluster out and doing some testing.
Posted: Fri Feb 22, 2008 9:19 pm
by smh0101
I'll check my old one that is dis-mantled at home if you want.
Posted: Fri Feb 22, 2008 9:26 pm
by asc_up
Go for it lol.
I'd buy the entire cluster from you, too. That's if it's for sale, of course.
Posted: Fri Feb 22, 2008 9:31 pm
by smh0101
Well. the speedo is fucked... but that and the tach is separate from the black surround thing that hold the temp gauge and the gas gauge...
Lemme look when I get home.
Posted: Fri Feb 22, 2008 9:32 pm
by asc_up
Yeah, the temp and gas are on their own piece of plastic. So I suppose that's all I would need.
Posted: Fri Feb 22, 2008 9:37 pm
by smh0101
And I do have that... and I did mess it up...
Posted: Fri Feb 22, 2008 9:42 pm
by asc_up
Hahahahaha no worries.
