instaling crankshaft key
Saskatoon Subaru
so i've got my engine back together, and i'm trying to put in the on my crankshaft, now should it just slid in or do i have to force it some how?
2010 Impreza WRX - 265hp
1990 Legacy 267,000km(Rebuild complete 265,423km----March 9/2008)
1991 Legacy Turbo 180,000km
Boostedballs
If you are talking about the timing gear and key- I would heat up the gear a little bit to make it 'larger' and it should go on without too much beating. If you do have to beat it on, use a deadblow hammer or a piece of wood to lighten the blow. Also, I would use some thread locker on the whole thing since these things have a tendency to wobble loose and tear up the crank.
Air-to-Water Intercooler, VF-39, 550 injectors, AEM FIC, stainless race header, 3" stainless exhaust, 75hp Nitrous, 150psi H2O injection, intake mods, stock: long block, 4EAT, ecm.
Saskatoon Subaru
Try cleaning out the key hole, and heating the end of the crank with a torch. You could even try putting the key in the freezer.
Saskatoon Subaru
Glad to hear it worked. Sometimes the simplest things work well
