Stock Up-Pipe vs. Aftermarket??
Posted: Thu Mar 13, 2008 1:02 am
by livestrong14
Hey guys,
Just wondering what your opinions were for the stock Legacy Turbo up-pipe vs an aftermarket stainless one?
Aren't ours almost exactly the same as a STi up-pipe? What benefits/ gains would you expect from an aftermarket one?
Thanks!
Posted: Thu Mar 13, 2008 3:24 am
by Damon
Probably nothing since ours are catless. You MIGHT get a little bit quicker spool if the aftermarket is smaller diameter but it probably wouldn't be worth the effort.
Posted: Thu Mar 13, 2008 3:33 am
by livestrong14
Yeah, I was thinking the same thing. The free up-pipe I got is definetely larger in diameter, and has a flex joint which is kind of nice.
Anyone else?
Posted: Thu Mar 13, 2008 1:19 pm
by BXSS
The STi & Legacy SS up-pipes look the same to me.
If the aftermarket U/P is bigger in diameter than the OEM one I'd think spool may slow down (less Exhaust gas velocity), but top end should be better (less backpressure).
Posted: Thu Mar 13, 2008 2:38 pm
The STi & Legacy SS up-pipes are exactly identical.
It's been posted before, but I confirmed this when I bought an STi up-pipe from a local guy when my old SS up-pipe had a crack in the flex part.
Posted: Tue Mar 18, 2008 2:10 am
by livestrong14
Anybody else feel like weighing in?
Posted: Tue Mar 18, 2008 3:43 am
by 555BCTurbo
These guys are right on Devan...
The only real reason to replace the up-pipe is due to age and use...but if that is the case, just grab an STi one...
Small up-pipe diameter is good...it means you get a greater exhaust velocity to the turbo = faster spooling = :D
So I'd say sell that up-pipe to someone that likes shiny things and then take the $$ and get yourself some steering rack bushings and a nice dinner!
