Weird 4eat Tranny
Posted: Fri Mar 14, 2008 9:36 pm
by Subtle
Had been running along a main thoroughfare at a steady 60 klicks for a number of miles. As in no launches or foot on the floor accelerations.
Turn off and come to a 4-way stop, with a slight upgrade.
In fourth, were it usually is, and in attempting to get through the intersection--engine spins with only enough forward motion to get part way thru.
Put it in neutral and rolled back to the stop. Tried third- range, and the same. But in second had no problem getting the few blocks home. Worked in reverse as well.
Been working all day and haven't tried it, but I'm sure it will be the same.
What is the problem and the cure? ?
Posted: Fri Mar 14, 2008 9:39 pm
by ericem
Check your fluid!
Posted: Sat Mar 15, 2008 12:24 am
by Subtle
Checked on Feb 23.
Posted: Sat Mar 15, 2008 12:55 am
by ericem
Check it today lol.
