Starter Differences?
Posted: Mon Mar 17, 2008 12:38 pm
by FormulaSuby
I was wondering if someone can help here. I have a JDM EJ20R motor and have it mated to a 1994 Legacy FWD transmission. Just tried cranking it over tonight, and the starter is quite a ways away from the ring gear. The starter I am using as well as the flywheel are from JDM car. Would anyone know if there are different length starters available? It is hard to tell from auto parts pics.
Thanks,
Posted: Mon Mar 17, 2008 4:29 pm
Dumb question -- did you apply power to the solenoid, or just the motor? The solenoid moves the pinion gear forwards to mesh with the ring gear.
Posted: Mon Mar 17, 2008 4:54 pm
by FormulaSuby
vrg3 wrote:Dumb question -- did you apply power to the solenoid, or just the motor? The solenoid moves the pinion gear forwards to mesh with the ring gear.
It appears to be a difference in starter position to flywheel location and/or tooth count. Power was to the solenoid...
Posted: Mon Mar 17, 2008 8:49 pm
by BSOD2600
Probably not very helpful, but there are length differences between auto and manual starters for the EJ22T.
