hi
dear all
my car wont start for tow days i dont know why?. anyway i try today to rotate my engine do u know what happin its make feed back air to airflow box like bomb. what this men plase
kind regards
bomb in airflow
bomb in airflow
legacy europe model LS 92
400.000 Miles
400.000 Miles
what happens when you turn the key, is the engine turning over and just not firing or does it just click?
and i ran you vin# through a decoder to figure what you were driving and your check degit came back invalid just thought i'd tell ya.
2010 Impreza WRX - 265hp
1990 Legacy 267,000km(Rebuild complete 265,423km----March 9/2008)
1991 Legacy Turbo 180,000km
sirSaskatoon Subaru wrote:what happens when you turn the key, is the engine turning over and just not firing or does it just click?
its just engine turning over without running while that my engine bush air strongly to airflowbox throug the thretlbody i mean inverse opreation.i hope u godt my point
thanks
400.000 Miles
400.000 Miles
It sounds like your engine backfired. That typically happens due to improper ignition timing or just an ignition system in poor tune.
When did you last replace the spark plugs and wires?
Does your engine have a distributor?
His car is just like ours. Like a Legacy L wagon. Just has a EJ20 motor. I am thinking it was the timing belt that broke or skipped because of a bad tensioner or pulley. He has a cam and crank sensor code and alot of others. So could also be a ground issue.
I had this happen on an old justy once.... You mean that there is air BLOWING through your intake instead of sucking it in? Sounds like either your timing belt broke (Really hyper sounding crank) or you have a stuck valve that is holding the intake valve open, maybe? My only guess is that the exaust stroke is pushing air out the intake manifold because the timing is off or one of the aformentioned problems
Subie Newbie
94 Legacy L Wagon N/A FWD (WTF)
No brags @ car, YET
No brags @ car, YET
