Hi beams not working
Posted: Mon Mar 24, 2008 7:33 pm
by ocs811
My hi beams aren't working, everthing else is,. I can flash them but when i push them on the headlights go out. Any ideas?
Posted: Mon Mar 24, 2008 7:49 pm
Does the headlight indicator on the dash go on when you flash the headlights?
Do both headlights work? Or just one?
Chances are the stalk is bad.
Posted: Mon Mar 24, 2008 9:01 pm
by ocs811
No the headlight indicator does not work and both lights don't work on hibeam but they do on low beam.
Posted: Mon Mar 24, 2008 9:49 pm
by ocs811
I checked when i flash the hi beams the indicator does flash.
Posted: Tue Mar 25, 2008 6:05 pm
Ok....if both hi beams and the indicator works when you use the "flash" on the stalk, then I'd still suspect the stalk/lever arm.
Posted: Tue Mar 25, 2008 6:14 pm
Me too.
