wiring problems
Posted: Fri Apr 04, 2008 1:14 am
So i swapped a EJ22T motor into an Impreza. I got the EJ18 ecu pinout and the EJ22T pin out. I did all the wiring but the light still will not come on and the car will not start it will just turn over. When i unplugged the B48 the light would come on but when its plugged in it wouldn't.
I decided to ground the major grounds like Natoe did so i grounded the ignition ground, 2 control system grounds, and the sensor ground. Before i grounded that i plugged in the last plug and the ECU light was still on.. but once i grounded it you could hear all the relays ( i believe they were relays) clicking on and off till i finally grounded it and no more ECU light.
I do put a diode in the right way the cathode(striped end) end goes to the self shut off control and the other one goes to the ignition switch pin.
Any help would be appreciated because i dont know what to look for next. Thanks, also could it possibly be my ECU that is wacked because this is the second time i did the wiring and the first time im pretty sure it was wacked so could i have fryed the ECU?
