Discharge ac compressor?? Can you DIY this??
anyone ever discharge the ac system by themselves? How would you do this? I'm putting in a new (used) ac compressor and need to discharge the system, do I really need to pay a shop to do this??
Also while on the topic of AC, I saw a kit at autozone that will convert any r-12 system to r-134a, it was pretty cheap too...anyone ever used this kit?? Does it work well? Thanks.
99 OBS 2.2 -auto
The trick with those kits is you still need to vaccum the system down before you re-charge it.
Unless you've got the vaccuum pump, your still in for a trip to the A/C guy. So, might as well let them discarge it for you. Some *might* even pay you for the R12.
what do you mean "vacuum the system down"..what does this do?PhyrraM wrote:The trick with those kits is you still need to vaccum the system down before you re-charge it.
99 OBS 2.2 -auto
To properly charge the system, there needs to be no air left in it. This means attatching a vaccuum pump and sucking all the air out before charging with the freon.
This is also usually the check for a leak system. Any leaks and it will not hold the vaccuum.
If you're going to discharge it, unbolt the fitting on the compressor, that way you don't need to be in the area.
Lol what?
To discharge it, you have to open the hood and mess with the relief valve in there or unbolt the fitting on the compressor.
You're not in the car when you do it...
