what is this connection beneath the drivers seat?
Posted: Thu Apr 17, 2008 9:41 am
by slowjoe
1
it is the connection on the lower right hand side of the picture.
2
same thing, just backed out to show you where it was in reference to other things.
Posted: Thu Apr 17, 2008 4:42 pm
by SubaruNation
looks like it is connected to the ABS, and from there to the ignition.
when you turn your car on, you can hear the abs lines start up.
pretty sure that's what that is.
Posted: Thu Apr 17, 2008 4:47 pm
by SubaruNation
maybe..... :?
Posted: Fri Apr 18, 2008 12:06 am
If you follow the wire on the seat, it goes to the seat belt buckle. I think it's supposed to be tied into the seat chime, but on my car, I don't believe it does anything......
Posted: Fri Apr 18, 2008 12:39 am
by slowjoe
subarunation-i dont believe i have abs. but i do hear something when starting up. before i crank the engine, when the key is just in the on position, the position that lets you get the check engine codes, i hear a noise. it sounds more like a pump.
josh-i wasnt talking about that. i am talking about the connections next to the door. they are currently connected. the seat belt wire is disconnected because i dont have the stock seat belts or the stock seat anymore.
Posted: Fri Apr 18, 2008 12:56 am
by SubaruNation
ahem,
these are abs lines. they have to be
the other thing you might be hearing is either the brake booster or maybe the PS pump.
Posted: Fri Apr 18, 2008 6:29 pm
SubaruNation wrote:ahem,
Nope, the brake lines run on the passenger side of the car.
Those lines are the fuel supply, fuel return, and evaporative emissions lines.
Posted: Fri Apr 18, 2008 7:14 pm
by SubaruNation
well they sure look like my ABS lines. good to know however :D
Re: what is this connection beneath the drivers seat?
Posted: Mon Apr 21, 2008 10:23 am
by legacy4ever
slowjoe wrote:it is the connection on the lower right hand side of the picture.
power windows harness.
Posted: Mon Apr 21, 2008 9:15 pm
by asc_up
slowjoe wrote:subarunation-i dont believe i have abs. but i do hear something when starting up. before i crank the engine, when the key is just in the on position, the position that lets you get the check engine codes, i hear a noise. it sounds more like a pump.
What you're hearing is your fuel pump pressurizing the system.
Posted: Wed May 07, 2008 2:28 am
by quicklook
that is correct. when my windows stopped working i had to mess with them. the circuit breaker is there if i remember right.
