How can i tell if my struts are bad???
Herm99
Post by Herm99 »
i've been an audi guy my whole life, and when the shocks blow you know it because they leak oil all over the shock body....i'm under the impression these are gas/air shocks, so how can i tell if they are bad? I have a mild hunch my front shocks are bad, front left one makes some strange noises. Any tell-tale signs??
Also, where is the cheapest place to get OEM ones, don't care about performance or lowering, just want stock/oem ones.
99 OBS 2.2 -auto
internetautomart
Post by internetautomart »
oil, as you already stated. too much bounce, noise.
if you think they are bad, they probably are. struts are not designed to last that long.
I can get you a good deal on some stock replacements if you want.
94 BC w/ AWD Sold 6/25/08
92 BJ Rust bucket gone
90 BC (I think) Stripper, gone since 2k
86 GL10 Turbo 4wd, Gone since 99
KYB GR2s are better and cheaper than OEM. They are gas. Gas struts are bad when they are stiff as hell or (later on) the car bounces all over the place. Oil struts just seam to blow out and bounce. The tire-kicker way to test is to push down on each corner hard and if it bounces more than twice, the struts are bad.
Herm99
Post by Herm99 »
internetautomart wrote:oil, as you already stated. too much bounce, noise.
cool, just sent you a PM. Thanks
99 OBS 2.2 -auto
Herm99
Post by Herm99 »
evolutionmovement wrote:KYB GR2s are better and cheaper than OEM. They are gas. Gas struts are bad when they are stiff as hell or (later on) the car bounces all over the place. Oil struts just seam to blow out and bounce. The tire-kicker way to test is to push down on each corner hard and if it bounces more than twice, the struts are bad.
Where do you recommend getting the KYB's from? Tirerack??
99 OBS 2.2 -auto
That's where I would get them, but there might be cheaper places. I think you can order them direct from KYB.
jamal
Vendor
Vendor
Post by jamal »
ebay tends to have them for cheap
internetautomart
jamal wrote:ebay tends to have them for cheap
and without warranty.
you need to be very careful about that, alot of stuff being sold on ebay doesn't come with a valid warranty.
chuckles
Post by chuckles »
The cheapest place I could find them: www.partsamerica.com
93 Legacy wagon- If my car was a chick it would be Jenna Jameson, used up but still getting the job done.
76 International Terra
internetautomart
same price as I quoted him on GR-2s
