Dash Cluster light problems
BlockerImp
Post by BlockerImp »
So, i just recently purchased a 93 SS, and un-beknown to me the dash cluster only has one light that works, which is the right side of the tachometer. Now you can understand how much of a problem that can be. now i have no prior knowledge as to wether they have been out for a while, or if its someone such as a blown fuse. Would a blown fuse be the culprit, or do i need to replace the lights in the dash cluster?
PhyrraM
Post by PhyrraM »
If one light is still on, it is a safe bet it's not the fuse.
You'll have to pull the cluster out to check the lights.
BlockerImp
well, i just need to know what kind of bulbs are used then. I found the other thread that shows how to take off the dash cluster, but now i just need to know what kind of lights they are
legacy4ever
Post by legacy4ever »
4 x T6.5 #24 Wedge bulb and 2 x 168/194/T10/W5W Wedge bulb, mine is euro-spec though.
Ben
93MY EUDM Legacy EJ22
BlockerImp
ok i found out. Its sylvania 54, and 178s
2 of the bigger 4 of the smaller
BSOD2600
Post by BSOD2600 »
Be aware of the different wattages for them though, they're ALL different. I had a few go out on mine, went to the subaru dealer and they couldn't even tell me which the correct ones to get where, since it depending on the exact bulb. I went ahead and found something that was the same size at the local Schucks. After getting them installed, it's obvious they're slightly brighter than the stock ones. oh well.
'11 WRX Limited
'94 TW | R.I.P.
Flowmastered87GL
Post by Flowmastered87GL »
Ha, all mine are burned out too. Except that on mine only the left side of the speedo works. And the CEL, oil light and battery light are missing all together :shock:
2005 Baja Sport
1991 Legacy L FWD Sedan
