Need a few last minute part numbers
Posted: Thu May 15, 2008 1:53 am
by livestrong14
Hey guys,
Just wondering if anybody knew the part numbers to the following parts. Their application is a 91 SS.
Parts
Whiteline ALK
Whiteline RCA kit
Whiteline ADJ rear control arms
Whiteline heavy duty rear swaybar mounts
Whiteline rear differential bushings
Thanks!!
Posted: Thu May 15, 2008 2:36 am
by EtchyLives
http://www.whiteline.com.au/docs/catalogues/WL_0350.pdf
This is one of my most often referenced .pdfs
ALK
Soft - KCA361
Race - KCA319M
RCA - I'm assuming you mean the rear camber adjust bolts
KCA414
But if you mean Roll Center Adjust then
KCA313
Rear Lateral Links (Note: This is for 92+. I'm assuming you've upgraded to 92+ rear suspension and these are what you're looking for)
4-piece - KTA108
2-piece (toe only) KTA107
Swaybar Mounts
KBR20-## (## is the number for the size of the bar)
Diff Bushings
Yellow (normal) KSB751
Black (Race) KSB751M
http://www.maperformance.com/store/prod ... t=0&page=4
Oops. Wrong part number for bushing kit. Added link
Posted: Thu May 15, 2008 8:34 pm
by ciper
Don't buy the race ALK unless you dont mind a bomb going off behind your dash at every bump in the road. It is the only part I regret buying :(
If you want the race one ill trade you for a soft one!
Posted: Thu May 15, 2008 9:31 pm
by jamal
yeah I'd recommend the sport alk. Even with that little bumps and expansion joints are fairly harsh in the car.
Save some money and skip the lateral links and swaybar mounts. You can get 04+ impreza swaybar mounts for like $20 and they're plenty strong enough. Then go with group n lateral link bushings, which are about $85 for all eight.
The thing I don't like about the adjustable links is when you have all adjustable links, the toe adjusters in the back holes, and possibly some camber bolts in the rear too. It'd be a huge pain in the ass to get things even. Although I also think having just the rear links adjustable with a toe lock kit would be ideal.
Posted: Fri May 16, 2008 8:31 pm
by ciper
I've got rear adjustable links. When I get an alignment I tell them to center the factory adjusters and just use the links to change toe and camber.
Posted: Mon May 19, 2008 5:56 pm
Yeah....when I put mine on. I set the factory ones somewhere in the middle I think, and they just used the links to make all the adjustments, which most alignment shops like because it's pretty easy.
