WTB: TDO4 turbo
Posted: Fri May 16, 2008 4:42 am
by 94legacy2.2
Im looking for a stock wrx turbo. Lines would be good with it but arent needed.
Let me know if you have one
Tyson
Posted: Fri May 16, 2008 12:35 pm
by Blackbart
I have the td04 turbo with an 06 WRX IC and fittings, this is a bolt up to our ej22t's. $225 shipped.
Posted: Mon May 19, 2008 2:55 am
by 94legacy2.2
Blackbart wrote:I have the td04 turbo with an 06 WRX IC and fittings, this is a bolt up to our ej22t's. $225 shipped.
All I need it the turbo. Will you sell the turbo seperate from the IC?
Posted: Mon May 19, 2008 2:59 am
by Blackbart
Yeah, I can do that
Posted: Mon May 19, 2008 3:37 am
by smh0101
How is it bolt in without the 90* intake?
Posted: Mon May 19, 2008 1:22 pm
by Blackbart
smh0101 wrote:How is it bolt in without the 90* intake?
If you use the the included TMIC there is no need for the 90* elbow.
Drops right in.
Posted: Mon May 19, 2008 2:48 pm
by smh0101
I'm not talking about the charge pipe... The part I'm talking about is the intake INTO the turbo...
Posted: Mon May 19, 2008 4:29 pm
by BXSS
I think folks use rubber hose of some sort for the inlet (? radiator or silicone 90* hose section) that should not be a big deal.
Posted: Mon May 19, 2008 9:12 pm
by 94SS_Canada
I used an ABS elbow, No clamping no leaks it works amzing, although it did need to be shaved a little bit
No kinks!
And It is basically a Direct bolt in although stock coolant lines have a metal bracket holding them apart for that VF you just need to cut them, it takes about 30 seconds.
Posted: Wed May 21, 2008 2:22 pm
by joshw02
please check your pm. I'd like to buy this setup.. Thanks..
Posted: Wed May 21, 2008 4:28 pm
by 94legacy2.2
Bump still looking for the turbo.
I havent heard from Blackbart so still looking
Posted: Sat May 31, 2008 7:39 am
by 94legacy2.2
bump.
still need one please
