08 Forester wheels?
Posted: Thu May 22, 2008 12:02 pm
by Dynamic Entry
anyone seen these wheels on our car?
I have been having a hell of a time trying to find 07 WRX wheels. someone has these for a great price in my city and I am thinking of caving
I just can't picture what they would look like really and I am not good enough with photochop
Posted: Thu May 22, 2008 6:54 pm
by Fkyx
Make sure they're the right bolt pattern!
Posted: Fri May 23, 2008 4:10 am
by DLC
They should look great.
They will fit.
If they're a great price, get 'em. If they don't work for you, sell 'em. Profit!
Posted: Fri May 23, 2008 4:40 am
by evolutionmovement
The earlier ones were lighter than the contemporary WRX wheels. Don't know if that would still stand, but it's a thought.
Posted: Fri May 23, 2008 6:40 am
by Dynamic Entry
yeah, the guy weighed 'em and said 20 lbs each.... not light
i think $425 for wheels that have 50 miles on them is reasonable, but I would never expect to flip them for profit
there is such little supply in my region, I have very few choices and I am very impatient
if I buy these I will probably paint them which is sad b/c they are spank, but fun b/c who cares
Posted: Fri May 23, 2008 6:44 am
by 555BCTurbo
Those in bronze would look teh good
Posted: Fri May 23, 2008 6:47 am
by Dynamic Entry
yes, bronze has long been on my mind and my grill is already bronze so i plan to match it
these wheels could be fun though, I am thinking of adding another color to the "sipe" line through the spokes
maybe black
Posted: Sat May 24, 2008 8:01 am
by stipro
I saw those on that "other" forum, and immediately thought you should get them. Its weird that you posted it here. Weird as in coincidence.
Posted: Sat May 24, 2008 8:13 am
by Dynamic Entry
I get you. I also am beginning to think I will be happy I got them....
what say you mike? sand first?
also, come get that axle and give that oil return thingy. :)
Posted: Sat May 24, 2008 5:53 pm
by SubaruNation
ya i would like to know also..
Posted: Sun May 25, 2008 12:12 am
by Dynamic Entry
some people are more thorough than others but the first two pages of this link have a few descriptions of what to do. sounds like everyone primes and one way or another the wheels should be ruffed up a bit first.
I am thinking a scrub down in the bath tub with steel wool. but first I will take them to the car wash and degrease+high pressure them...
http://forums.nasioc.com/forums/showthr ... ing+wheels
Posted: Sun May 25, 2008 3:29 am
by SubaruNation
nice!
i'm thinking gold..
but i am also going to go through all of that nasioc thread too..
Posted: Sun May 25, 2008 3:52 am
by SubaruNation
what do people mean when they say "wheel weights"
i dont get it
Posted: Sun May 25, 2008 4:58 am
by stipro
Dynamic Entry wrote:I get you. I also am beginning to think I will be happy I got them....
In regards to the wheels, definitely sand then first. I would just wet sand with 400grit. If you don't sand through the clear you shouldn't have to prime.
I will call you tomorrow for sure. Thats the day you said you have off right??
Posted: Sun May 25, 2008 6:50 pm
by Dynamic Entry
SubaruNation wrote:what do people mean when they say "wheel weights"
i dont get it
they are little weights that range in mass (a really big one is 3 ounces) that must be attached to the inside and outside of wheels in random/varying degrees and placements to make the wheel balanced
ordinary ones simply clip onto the edge of the rim but you can get sticky ones to stick inside the lip so that your wheel face doesn't have a weight showing
here is a wheel weight that has been painted over. if he remounts the wheel they will probably have to rebalance them and then he will have a silver spot underneath there
Posted: Sun May 25, 2008 6:52 pm
by SubaruNation
ah, ok got it
Posted: Sun May 25, 2008 9:29 pm
That guy's tire shop sucks - that wheel should be balanced with stickies on the inside, but I guess he doesn't care much about doing what's right since he's painting over the weight. Any time you change a tire, you need to rebalance the wheels.
Posted: Sun May 25, 2008 9:32 pm
by Fkyx
Les Schwab put my weights on the outside. But my stockers look pretty trashy, so I don't blame them. Maybe next time I'll ask for stickies.
Posted: Sun May 25, 2008 9:33 pm
by SubaruNation
hmmm.
can i just pull that weight thing off, and put it on in the exact same place when i get done painting the wheels?
Posted: Sun May 25, 2008 10:04 pm
by Dynamic Entry
probably, if you aren't changing the tires...... even though it goes against standard thinking of what is right
unless you are heavy on the paint on one side ;)
I think there is a specila tool to pull off weights but you might be able to get it by pulling at the crease with a flathead
Posted: Sun May 25, 2008 10:20 pm
A pair of vise grips can get them off, just be careful with the alloy. Don't know if you'll get it back on - they're not designed for reuse. The special tool is a hooked plier. They may sell them at Pep Boys or something. Lazy techs will use the clip on weights if there's a lip and they're not specifically told to use the stickies because they're much easier - you just hammer it on, while the stickies require the cleaning of lots of brake dust and making sure they stick.
Posted: Mon May 26, 2008 5:12 am
by SubaruNation
lol im just going to paint over them :lol:
they will be winter wheels eventually
