Page 1 of 2
really high idle SOLVED
Posted: Wed May 28, 2008 9:34 pm
by what huh
I unplugged my IAC and thats drops my idle from 4000 to 2500 rpms so thats not the problem.
Anybody else have any other ideas, as to a solution?
Posted: Wed May 28, 2008 9:46 pm
by ciper
I'd say no.
Posted: Thu May 29, 2008 3:31 am
by Ej22TIM
you need a new iac.
or if you have a topmount make sure your intake boot isnt ripped.
Posted: Thu May 29, 2008 5:35 pm
Before you go and replace anything, can you give a little more info as to the background of the engine setup, etc. Did this all of a sudden occur, are you doing some work, and not have everything complete, etc.
Posted: Thu May 29, 2008 5:52 pm
by what huh
this project started in three peices: shell, engine, tranny . . . the major peices anyways.
It has been going this since the first start up, but hasn't been runnig for more than 30 secs each time it has been started
the IAC would make since tho, because when i got the car it was dangling by the wire
Posted: Thu May 29, 2008 6:03 pm
unplug the IAC connector, start the car and see if you get the same high idle characteristics.
Posted: Thu May 29, 2008 7:29 pm
by what huh
ah . . . . . thats a good idea
you know if it wasn't for you all, the world would be a Legacy-less place.
There are a countless number of people with a countless number of answer and i don't know what i would do with out them
Posted: Thu May 29, 2008 8:52 pm
by Fkyx
My car jumps up to about 2500 when I start it up, and it doesn't normally drop below 1000 (when it does drop) until it's at operating temperature.
Maybe yours will drop if you let it warm up a little more.
Posted: Thu May 29, 2008 11:09 pm
by what huh
yeah thats what my buddy was thinking
Posted: Fri May 30, 2008 12:18 am
by ericem
what huh wrote:yeah thats what my buddy was thinking
Maybe your coolant sensor is the problem? The ECU one then.
Posted: Sat May 31, 2008 1:42 am
by what huh
i unpluged the IAC and the idle dropped to 2k rpms.
so im going to get a new one and see what happens
Posted: Sat May 31, 2008 3:42 am
by ciper
Did you try turning the shaft while the car was running?
Posted: Sat May 31, 2008 6:54 pm
by what huh
you mean like trying to drive it
Posted: Wed Jun 04, 2008 11:34 pm
by what huh
Ok so i unpluged the the IAC and the idle dropped down to 2500 from 4000.
Any Ideas on to why the idle is still high?
Posted: Thu Jun 05, 2008 12:32 am
by ChesterKV
what huh wrote:Ok so i unpluged the the IAC and the idle dropped down to 2500 from 4000.
Have you tried cleaning the IAC ? On the EJ22 n/a (I'm guessing yours is similiar or identical) you remove the IAC from the intake manifold and then it comes apart into two sections. Some coolant will spill so only do this when the engine is cold. Buy a new gasket for reinstalling the IAC or you can try reusing the old one.
IAC on left (throttle body on right) removed from intake manifold
Mark the position of the screws with a marker of some kind... you may still see the white factory marks so you can also use those. I can't remember if the brake cleaner cleans off the factory white marks so perhaps it's best to use a permanent marker.
Popping the top off....... there's some funky magnetic resistance but it'll come off.
Shoot a lot of brake cleaner into this green area while rotating the shaft around. You should see black residue come out. All you're really doing is cleaning the area enough to allow the shaft to rotate correctly again. Don't forget to apply brake cleaner to the hole in the top that you removed.
Reinstall everything taking care to have the top EXACTLY where it was before you removed it from the main body. Reinstall IAC with new (perhaps used depending upon condition) gasket. Try pinching the skinny coolant lines to help purge the air out.
You should be good to go now.
When I did this my high idle (I think it was over 3,500 rpm) at start up immediately went away.
-Chester
Posted: Thu Jun 05, 2008 12:47 am
by what huh
k i will d this as soon as i get another gasket, because mine is bad.
Posted: Thu Jun 05, 2008 1:27 am
by ciper
what huh wrote:k i will d this as soon as i get another gasket, because mine is bad.
Uhh... I'd wager that was the problem in the first place!
Posted: Thu Jun 05, 2008 3:29 am
by what huh
because of the bad gasket comment?
Posted: Thu Jun 05, 2008 3:33 am
by ciper
If the gasket is bad it will let air into the intake after the throttle plate! That would raise the idle substantially.
Posted: Thu Jun 05, 2008 3:42 am
by what huh
yeah but i dont know if it was bad before i took it off. But it did break when i pulled it off
So now i have to replace it haha
WOOOHOOOOO Second Gear
Posted: Tue Jul 22, 2008 12:07 am
by what huh
that wasn't the problem
Posted: Thu Jul 24, 2008 8:40 pm
by what huh
anybody
Posted: Sun Jul 27, 2008 3:05 am
by what huh
could it be my throttle position sensor
Posted: Sun Jul 27, 2008 10:40 pm
by what huh
So I get done putting in the new IAC gasket and same problem 4000rpm idle
And then i checked for vacuum leaks . . . NONE
and then me and friend were staring at my car and i noticed that the . . .
FRECKING SET SCREW IS SCREWED IN
so i turned it back and she idled at 800rpm and then i started to smile. And i dont think im going to sell her anymore
Posted: Mon Jul 28, 2008 12:15 am
by 94SS_Canada
What is the Set screw?
Does that regulate idle?
pm me please
