Like my new turbo?
Posted: Mon Jun 02, 2008 10:47 pm
by 555BCTurbo
You think this setup will make any power?
Posted: Mon Jun 02, 2008 11:39 pm
by Fkyx
Jeez. lol
Posted: Mon Jun 02, 2008 11:55 pm
by livestrong14
haha Holset FTW!
Posted: Tue Jun 03, 2008 2:03 am
by smh0101
haha... nice Nick
Posted: Tue Jun 03, 2008 2:33 am
by Aerotech
Holy jet engines, Batman! When does it spool up, around 6 grand??
Posted: Tue Jun 03, 2008 2:47 am
by 555BCTurbo
This is a complete joke, you know that right?
That turbo is off of like an L10 Cummins or something similar...and it won't even physically fit in the engine compartment...
If I was turbocharging a 572 Chevy or something, it might work, but not for 2.2 Subaru applications.
Posted: Tue Jun 03, 2008 4:39 am
by smh0101
Slap that thing on an 8.1L Chev V8
Dammmnnnn... Crazy...
Posted: Tue Jun 03, 2008 5:13 am
by 555BCTurbo
smh0101 wrote:Slap that thing on an 8.1L Chev V8
Garbage engine...
I won't be slapping it on anything...because it ain't even mine...
Posted: Tue Jun 03, 2008 6:03 am
by dropdfocus
You know a turbo is large when... you can read Holset on the side of the turbo from a range of 10 feet away!
And no, it spools up to 3.1 psi at 10,500 rpm on a 4 cyl motor.
Posted: Tue Jun 03, 2008 6:05 am
by smh0101
555BCTurbo wrote:smh0101 wrote:Slap that thing on an 8.1L Chev V8
Garbage engine...
Yeah, probably... But it sure makes a Suburban haul ass...
Posted: Tue Jun 03, 2008 1:49 pm
by BXSS
Nice Turbo/Pic!
We were looking for something BIG for the Welfare Racer & ended up getting another GT45R (over budget - 4.25" compressor inlet / 3" outlet), but we have used 18wheeler turbos on 1.1l Rotary engines with excellent results.
With this infusion of $ we expect to improve 1/4 mile times from 9.97 - 9.3-9.5s.
The last incomplete pass (no 4th gear 9.98 et) made had a 6.222s 1/8th mile et @ 108MPH which should have translated to a 9.7ish pass.
The non-ghetto 1.3l twin of the Welfare Racer makes 30psi free revving a GT45R @ a little less than 1/2 throttle.
If this car does not run 8's off the bat with the potential for LOW 8's it will get crushed...
Is the inlet of that turbo about 4" (looks almost the same size as the strut top) & the outlet 3" ?
Posted: Tue Jun 03, 2008 6:47 pm
by 93forestpearl
I think it could be massaged in there.
Posted: Tue Jun 03, 2008 7:04 pm
by BXSS
+1 - 93forestpearl always has good ideas!
Posted: Wed Jun 04, 2008 12:50 am
by brando
Looks small..
Posted: Wed Jun 04, 2008 1:02 am
by n2x4
Did you try throwing some clamps on your turbo piping? I think your boost leaks are the reason it won't work on the car
Posted: Wed Jun 04, 2008 3:49 am
by 555BCTurbo
I hope that winky is to denote the fact that I simply set the turbo in the engine compartment and took the pic...if you look really hard you can see the VF39...
Posted: Wed Jun 04, 2008 5:00 am
by smh0101
I was about to say...
I spy a vf39!
Posted: Wed Jun 04, 2008 5:53 pm
by n2x4
Well then that's the problem, your plumbing for a biturbo setup is all wrong .
Posted: Fri Jun 06, 2008 6:43 am
by Laura
You could make a hood scoop, Nick!!
Who cares if it blows up your engine!
Posted: Fri Jun 06, 2008 6:48 pm
by 555BCTurbo
Laura wrote:You could make a hood scoop, Nick!!
Well, with that mentality...why don't we just put it on Pearlie?!?
