EJ25 DOHC fuel rails the same as 91-94 NA rails?
deamon64
Post by deamon64 »
As the title says. I know both are side feed and i need injectors, at least 650cc and have read that nissan side feeds work in the 91-94 NA rails, just want to know if they will fit into my EJ25 DOHC rails.
Cheers,
Joel
Can you please provide more specifics to the model & year subaru.
The 92-94 n/a fuel rails will accept the STi yellow 550 cc/min injectors....and should accept any similar type injectors.
deamon64
Post by deamon64 »
pretty sure the heads are from a 97 leg GT
douglas vincent
Post by douglas vincent »
They "should" work. I just test fit some side feed rails off a 2.5, and the 550 STI injectors fit.
the EJ25D rails also take the nissan sidefeeds. I happen to have one of the manifolds on my workbench at the moment.
deamon64
Post by deamon64 »
thats awesome thanks a lot
cheers,
Joel
