Swapped 96 LSI wheel to 93 L and air bag light is stuck on ?
Posted: Wed Jun 11, 2008 8:57 am
I just finished putting a 96 Legacy LSI steering wheel on my 93 L wagon. I had to use the 96 roll connector since it was shorter than the 93 roll connector plus the alignment pins were at a different angle. All the connectors were plug and play even the cruise. The horn on the 93 used a ground to the wheel since it had buttons and the 96 didn't since it's just one big pad. The horn works fine so does the cruise control. My problem is the air bag light stays on? Can I reset it or is there anyway to get it to turn off? My 93 wheel was is totally sun faded and soft so that is why I swapped it out with the 96.
THANKS FOR ANY HELP
THANKS FOR ANY HELP
