EJ20R Intake manifold COMPLETE-$250
Posted: Wed Jun 18, 2008 12:36 am
by BXSS
I have a EJ20R intake manifold completely assembled with everything (IAC/hoses, 480cc yellow injectors/rails...) except t-body.
I do not think I'll be using it so I'll let it go for a reasonable price (Injector + Raw Manifold Value).
PM me reasonable (not low-ball) offers...
Posted: Wed Jun 18, 2008 1:31 am
by smh0101
Are these under intake manifold intakes or elbow intakes?? All I know about ej20rs is that the manifolds will work on 20g heads etc.
I definitly may be interested if its the elbow one...
Posted: Wed Jun 18, 2008 1:28 pm
by BXSS
Under intake turbo inlet.
This is the PI bolt pattern so it will fit 2.5DOHC, EJ20G, EJ20K, EJ20H, EJ20R heads.
One nice thing about these intakes is the ports are just about perfectly gasket matched from the factory...
I also like the under manifold inlet which opens up the possibility of using a straight inlet'ed upgrade turbos like the newer cars do (VF39, VF23, VF22........).
I have the correct p/s pump, coolant bridge, & airbox/tubing to do a under manifold inlet conversion that I can supply if needed...
Posted: Fri Jun 20, 2008 6:34 pm
by BXSS
Updated $250 takes the manifold complete (Less t-body) & your choice of the Yellow 480cc injectors (on the manifold from the factory) or grey 440cc injectors.
