turbo timer....
Posted: Fri Jun 20, 2008 11:33 pm
by g20sleeperjdm
anyone have any real experience installing a turbo timer in a 1992 ss or similar? i have a really good deal on an hks type 0 and wanna buy it.. do i need a harness for it? what fits? thanks in advance everyone
Posted: Fri Jun 20, 2008 11:38 pm
by ciper
You dont need a harness for it but its a good idea. You could build one yourself with chunks of the ignition wire harness from a junkyard. Just make yourself a little "extension" cable and wire the timer into it.
If you do it this way its a LOT easier to troubleshoot when the gremlins come out to play.
Posted: Sat Jun 21, 2008 3:16 am
by g20sleeperjdm
does anybody know a company online that sells any? or what other cars use them that maybe our older leggys can use?
Posted: Sat Jun 21, 2008 1:31 pm
by BXSS
I have an HKS one that I never got around to installing & the wiring is super simple I think there are only 5 wires than need to be hooked up 2 of which are "+" & ground.
Posted: Sat Jun 21, 2008 9:14 pm
by g20sleeperjdm
BXSS wrote:I have an HKS one that I never got around to installing & the wiring is super simple I think there are only 5 wires than need to be hooked up 2 of which are "+" & ground.
what application is your harness for tho?
Posted: Thu Jun 26, 2008 6:48 pm
by BXSS
I have a GC8 harness as I was going to use this on my OBS-T, but the 5 wires I was talking about come straight out of the t-timer.
I found the instructions online - did not look like a big deal to hook up without an adapter harness.
