what the hell can I do about this? I was driving along and the spark plug blew right out of the top of the cylinder, taking the threads out with it. WTF!!!!!!!!!!!!!!!!!!!!!!!!!!! I am going to die
silver 94 turbo ss need lower control arm
01 maxima daily beater
95 ford contour trans blown
Are they Turbo heads? I bet you could get a used set for cheap.
Did you find the spark plug? Does it have any physical damage on the end? I bet you 5$ someone overtightened them in the past which weakened the threads.
I think they are turbo heads, it's an ej22t motor and I never changed them, should I take this as an opportunity to upgrade the heads? are there better plug and play heads? Is It a major pain in the keester to swap heads? I did the t belt twice cuz I lined it up wrong first, that was a bitch. Is it worse that that?
Well I would recommend removing the motor to get at them. I heard it's possible to do them with the engine still in the car though. Aren't EJ20G heads a better flowing upgrade?
My brother did this same thing to a '94 Jetta GL. My dad's mechanic only charged like $75 for a helicoil job and new spark plug. But that guy's rate is almost half what most shops charge nowadays....
as soon as this happened I went and bought a 2001 maxima. I'm happy now I can finally soup my car up while driving the nissan. Anyone with parts for sale bring em on!
