whats wrong
Posted: Fri Jun 27, 2008 2:14 am
by d_timmons
why does my 94 legacy awd hit the rev limiter at 4200 before it even shifts. its really annoys me. please help
Posted: Fri Jun 27, 2008 2:25 am
by Ej22TIM
sounds like its starving for fuel, replace the fuel filter and run some injector cleaner through us and let us know what happens.
Posted: Sat Jun 28, 2008 5:18 pm
by d_timmons
its notstarving for fuel its hitting te rev limitelike some one was messing with the computr but no one has
Posted: Sun Jun 29, 2008 5:31 am
by ericem
Maybe there is a issue with the TPS ( throttle position sensor). Can you still hit redline if you floor it aka 6500rpms?
Posted: Mon Jun 30, 2008 3:36 am
by d_timmons
it can still rev past that if i am in park or neutral. but here is the weird part i put in a new cd player and it let me red line in drive today, so i think it is a short somewhere. now my parking lights and dash lights wont turn on either, the guy who had it before me butchered the wiring harness for the radio so i dont know what is all screwed up. i guess it is good luck to me.
Posted: Mon Jun 30, 2008 5:56 am
by SubaruNation
i'd hunt that person down first,
is your IAC hose connected to your bypass valve ok?
maybe change your 02 sensor...
or speedo is busted?
Posted: Mon Jun 30, 2008 3:09 pm
by d_timmons
it has a new o2 sensor. the speedo is off a couple mile an hour but that shouldn't affect the shift. and what is a iac hose
Posted: Mon Jun 30, 2008 5:02 pm
by 93forestpearl
The ECU gets its speedo signal from the spedometer itself, since its opereted by a cable. The "reed switch" is what sends the signal.
Maybe that got chopped somehow?
Posted: Mon Jun 30, 2008 8:17 pm
by SubaruNation
it connects to your large black "charge pipe"
that goes from your throttle body to your turbo intake outlet.
the bpv is underneath that
