				Fill UR own mounts?
				Posted: Thu Jul 03, 2008 12:57 am
				by New92
				So has anyone tried to use the windshield urethane trick?  I used it on my old neon but was curious if the results are  similar on these much older chassis.  I know of old school drag guys that will use nothing else and am curious if there is anybody out there using this in the ol'tleg.
Thanks.
				Posted: Thu Jul 03, 2008 6:33 am
				by ciper
				Subaru sells hardened mounts that aren't very expensive. Because of it no one has had to create their own.
				Posted: Tue Jul 15, 2008 6:14 pm
				by NuwanD
				Works like a charm in the transmission mount since there are several voids to fill. You'll need almost one full tube to do the tranny mount alone.
Subaru engine mounts do not have enough voids to make a difference.
				Posted: Tue Jul 15, 2008 6:36 pm
				by evolutionmovement
				I need to do this for the sissy Mazda.  The liquid-filled control arm bushings always felt wussy, but now the car has weird issues while cornering that can only be the problematic Ford bushings.  The motor mounts are a known issue and nobody makes aftermarket urethane parts.  If only Subarus didn't get so damned ugly and heavy...
				Posted: Tue Jul 15, 2008 8:18 pm
				by n2x4
				Like this?
Something to note, I put duct tape one one side of the mount and then squirted the window weld in.  Strangely enough, after 2 days the side with the tape was still gummy.  I removed the tape and waited another day.  Still gummy.  I used goo gone to remove the left over duct tape sticky residue and by the end of the day all parts of the mount were solid.
I don't suggest using duct tape, but try using something to make sure the poly doesn't flow out the other side.
				Posted: Wed Jul 16, 2008 4:22 am
				by Hocrest
				Where are you getting this stuff? I tried looking for it a few years back, and none of the local places had it...
It probably didn't help that I wasn't exactly sure what to ask for...
Me - Yeah, I'm looking for a windshield adhesive that I can use to firm up my tranny mount
AZ guy - We have this stuff to re-attach your rear view mirror...
				Posted: Wed Jul 16, 2008 4:48 am
				Posted: Wed Jul 16, 2008 1:07 pm
				by n2x4
				Advanced Auto has it.  It's called 3M Window Weld.  Comes in a caulking tube.  Costs about 9 bucks.
				Posted: Fri Jul 18, 2008 1:12 am
				by New92
				n2x4 wrote:Like this?
THanks for that tip.  I think Ill try wax paper then tape that to the mount.
				Posted: Fri Aug 01, 2008 3:30 pm
				by BXSS
				I did this on a few cars including the tranny mount of my OBS-t.
It works well & is CHEAP!
				Posted: Fri Aug 01, 2008 4:21 pm
				by PhilSine
				Checker/Shucks/Kragen also sells it.
				Posted: Fri Aug 08, 2008 3:44 pm
				by shtbxr22
got a quicker way? there is alot o' shit there
				Posted: Sat Aug 09, 2008 3:26 am
				by greg donovan
				my brother did this too to the tranny mount.  worked pretty well.
				Posted: Sun Aug 10, 2008 9:06 pm
				I've actually got some 80 durometer stuff I bought back when.  If you want it, make me an offer.
