Page 1 of 2
Driving like a 95 year old has it's rewards
Posted: Thu Jul 03, 2008 3:45 am
by James614
Just measured 22mpg in my Touring Wagon today on 5/8ths of a tank. The best I ever got previously was 19.2 and I usually get a solid 18.4 - 18.8. Had to stay under 2000rpm 99.999% of the time to achieve this
Not quite the payoff I was hoping for considering that our HHR at work went from 28mpg to 35mpg with similar methods.
Whoever came up with that "6cyl power with 4cyl economy" for turbo fours should be shot in several non-fatal places.
Posted: Thu Jul 03, 2008 4:04 am
by douglas vincent
Replace O2 if you havenet in a while
by douglas vincent
with OEM!!!!
Posted: Thu Jul 03, 2008 4:15 am
by Murphy
i got 28mpg on my last fill up at 1/8th tank, which is driving normally, if i had an SS i dont think i would have the amount of will power it takes to keep it under boost
...thats why i want to go diesel
Posted: Thu Jul 03, 2008 4:25 am
by Aerotech
Yeah, but you'll end up going turbodiesel, putting in intercoolers, water injection, boosting to 25psi... once you go turbo, it's impossible to live without it, and equally impossible to avoid tweaking the motor for more power. I'm going diesel with the Syncro, and it's happening as we speak. Parts are in the mail
Posted: Thu Jul 03, 2008 5:42 am
by Fkyx
I turned my boost down last week. It almost makes me cry when I get on the gas.
At least it still scares little children.
Posted: Thu Jul 03, 2008 1:25 pm
by James614
Murphy wrote: i dont think i would have the amount of will power it takes to keep it under boost
Took me almost year with my TW to finally stay out of it between just 1 fillup. Right now its a damn good thing I can't afford an intercooler, cause I have a MBC sitting on my desk and I know things are going waaaaay south once that snowball starts rolling.
Posted: Thu Jul 03, 2008 9:53 pm
by SubaruNation
i average 26 with my tw...
weird.
ya just stay out of it and go 65 on the highway and you get good MPG
Posted: Fri Jul 04, 2008 1:07 am
by beatersubi
Ya, it sounds like you're due for a tune-up. Try plugs (oem or equivilant), wires, and pcv if you haven't recently.
I average ~25 in my turboswapped legacy wagon, and traffic (people) piss me off most of the time.
Posted: Fri Jul 04, 2008 3:08 am
by James614
I'm starting to wonder about differences in our fuel economy calculations.... EPA for the TW is only 18/23. And the EPA ratings are reduced 15%/10%, respectively, from the actual results. So I find it hard to believe that me achieve within 99% of them in real-world driving is so far below what I should be getting...
Posted: Fri Jul 04, 2008 4:37 am
by DLC
At 4500ft, my GT got me just shy of 28MPG over the course of 360 miles (16 gallon tank), with about half of that highway (55-65mph) and city (25-55) and NO AC (crack the windows).
I think altitude helps me, because if there's less air and no forced induction, I have less potential power, so less fuel will be used by default.
Still thinking about something 35MPG+ though.
Posted: Sun Jul 06, 2008 2:46 am
by SubaruNation
DLC wrote:At 4500ft, my GT got me just shy of 28MPG over the course of 360 miles (16 gallon tank), with about half of that highway (55-65mph) and city (25-55) and NO AC (crack the windows).
get a...
Posted: Sun Jul 06, 2008 2:59 am
by Murphy
if you drive 1000 miles a month at 28mpg
thats around 35gallons a month which is around $140 a month which is about $1700 a year
the Tesla Roadster cost $109,000 so in order to get your moneys worth you would have to make it last 64 years before you ever saved a penny on fuel
Posted: Sun Jul 06, 2008 3:12 am
by SubaruNation
ya, you're point?
Posted: Sun Jul 06, 2008 4:38 am
by ericem
SubaruNation wrote:ya, you're point?
Keep the Subaru!!!!!!!!
Posted: Sun Jul 06, 2008 8:18 am
by 86ruguy
well, before i screwed up my car(btw...not sure it was my fault) i was getting about 20.5mpg driving 26 miles one way to work with 50% of that time spent idling because of traffic. plus all of the round town driving i was doing in the time i was not at work. i was going thru about 7 tanks a month. 15x4.20=$63.00x7=$441.00 a month in gas
since my car broke 3 weeks ago, i have spent $37.50 on the bus and train getting back and forth to work.
$37.50x3=$112.50
so even when you add in the gas i have to put in my wife's car, i still come out ahead on fuel costs. BUT BOY DO I MISS MY FRIGGIN CAR!!!!!!!
Posted: Sun Jul 06, 2008 7:54 pm
by SubaruNation
ericem wrote:SubaruNation wrote:ya, you're point?
lol i know i was kidding
Posted: Sun Jul 06, 2008 9:31 pm
by scuzzy
well I drove 220 miles Friday night and burned through most of a tank of fuel (10.8 gallons I think the total damage was)
I set the cruise at 90 (it was 11PM) and let the car take me home. I filled up the next day and my mileage came out to 20.6 or something like that.
Cruise kept the boost just under 0vac most of the way; was turning 4000-4100 rpms - I'd only go into boost on the steeper hills and usually it was no more than about 3-4 PSI; sometimes I hit 6 or 7 but not often.
Posted: Mon Jul 07, 2008 4:00 am
by SubaruNation
im starting to think that staying out of boost isn't worth it.
i've used a tank and stayed out of boost most of the time (alot) and never gone over 70 on the highway.
i ended up with only ~240 miles on the tank.
but i did fill it up before i actually hit the low tank warning.
so i guess i could have made it to like ~270
Posted: Mon Jul 07, 2008 5:22 pm
by SILINC3R
i get about 30 mpg driving to work and around town. if i was to go on a trip i am sure i could get around 40.
Posted: Mon Jul 07, 2008 5:54 pm
by Murphy
40? i think that is stretching it quite a bit
Posted: Mon Jul 07, 2008 6:30 pm
by douglas vincent
Remember, smaller tires will give you inflated MPG numbers cause they turn more, causing you to "travel" farther distances.....
I have changed to running 89 octane (plus) versus 87 and it really seems to help, like 3-4 mph better, which easily pays for the gas price difference!
Posted: Mon Jul 07, 2008 7:30 pm
by NuclearBacon
With my 5mt Swap, freeway miles, i can get a consistant 26mpg... If i'm driving a 300 mile trip on the freeway and i'm cruising at 65 to 70 mph, i've gotten 28mpg before!
That was neat
Posted: Mon Jul 07, 2008 11:47 pm
by ericem
douglas vincent wrote:Remember, smaller tires will give you inflated MPG numbers cause they turn more, causing you to "travel" farther distances.....
Does that tell you that your knock sensor is bad maybe?? European cars didn't have knock sensor's but just ran high octane.
Posted: Tue Jul 08, 2008 12:47 am
by evolutionmovement
The opposite if anything - it could be pulling the timing back on the lower octane or advancing it on the higher, depending on if the turbo 87 recommended. If the knock sensor didn't work the ECU is supposed to know and it's supposed to put it in safe mode (although mine didn't do that) and not care what the octane is.
