04' STi Struts, recap and a couple ?'s
Posted: Thu Jul 10, 2008 8:18 pm
I recently bought a sweet setup that is based off of 04' STi struts and upgraded springs. I know this isn't the ideal setup with regards to alignment and track width, but I just couldn't pass up the deal.
So I've been doing a lot of searching on the experiences that Jamal, Thawa, Brat4x4, and some others have had. I think I have a feel for the situation but wanted to recap my understanding so those that are experts can correct me if needed.
To be upfront with my goals in regards to performance and how I drive - this car is my daily and I do put a fair number of interstate miles on it. I do Auto-X it though and also enjoy the windy roads on occasion. So I will need enough negative camber to keep it exciting, but not so much that I kill my tires if I'm not taking a lot of corners. I still have a bit of learning to do on what settings I'm after but thinking around -1* up front and -.7* in the back?
Fitment into the strut towers -
The fronts will bolt right in, no problems here.
The rears will not go in stock and here I have two options. First is file out the holes in the strut tower to allow the wider bolt spacing. I am opposed to this for two reasons, first is I don't want to do this and have my struts mounted in elongated holes. I know it's been done and works, but a personal preference says no. The second reason I don't want to do this is I have a nice Cusco rear strut bar that I'd like to continue using and have no desire to try and file out those holes. The solution to this, as I understand it, is to source a set of 90-91 tophats as the 04' springs are tapered. So if I get the 90-91 tophats then everything bolts right in.
I am assuming that the rubber the spring seats against will transfer from the 04' tophats to the 90-91 tophats?
Alignment - Here is where it starts to get fun and I'm looking for confirmation I have things right.
Since I was just talking about the rears, I'll start here. The STi track is wider than the BC, so swaping in these struts induces a positive camber. Filing out the holes reduces this though - but I don't want to go that route. I know Jamal uses Intrax camber bolts in the rears. Will this be enough for me to get my car setup the way I want or will I need a set of camber plates as well? If I put in camber plates, do I loose the extra bolt height on the tophats that I need to mount the RSTB?
Upfront I know I'm facing just as many issues/customization. Jamal has milled out the holes on his struts to allow the use of two camber bolts per side, using stock camber bolts. This has gained him some room but not as much as he was wanting. The bottom hole is already cammed and just the top needs cammed? Do you have any dimensions that I could use? I do have access to a milling facility. Should I just look at camber plates off the bat? I know the RCE's are ~$400 but I think there are a few others though they don't offer the same degree of adjustability.
I hear a lot about Caster, and truthfully do not understand this variable. I can see the tire being aligned with regards to two axii, longitudinaly and perpendicular to the axis of rotation within the horizontal plane. What is caster?
So yeah, I'm trying to get everything figured out so that when I go to install these it's a one time ordeal and I don't have to mess with my suspension for 30k+ mi., outside the occasional alignment. Please fill me in on where I am in error and any other items I've missed.
Thank you in advance.
