TPS interchange?
James614
TPS interchange?
Post by James614 »
Anyone know if an OBD2 TPS will work on our cars? I'm looking to try one from the boneyard and would prefer if one less than 15 years old was an option.
Different kind of TPS. Our cars use a 4-pin TPS with an integraded idle switch. The newer TPS's are 3-pin and don't have the integrated idle switch.
def09
TPS
Post by def09 »
Stick with one from a 1990-1994 Legacy. If you cant find one easily local contact Blackbart on this board.
