my timing belt exp.
my timing belt exp.
so my car leaks oil like a bitch, right on to the exhaust at the front of the engine, car now has 119,000 km on it, and the timing belt is stock which means it's about 20,000 km overdue.
so i ripped it allapart with a buddy, first by finding top dead centre, to do this we lined the crank pulley line up with 0* timing, not sure if this is the proper way but it worked, cracked the nut by turning the engine slightly while i held a socket on it, then pulled the pulley off and lined the crank properly then lined the cam's with there marks tightened everything upnad started it, ran perfect, oh yeah and we changed the seals, pass. side was a bitch. then we put the cover back on and i took off home and then to seattle, 250miles, and back to pick up a 06 ic. anyways, this was all yesterday, today on the way to work my engine died, wtf. i
i pulled the left and right covers and noticed chunks of the tb cover rubber gasket which had been stretched out and did not go on properly. i did not have time to take it all apart but i'm thinking the belt slipped from the chunks getting caught in it?//
my other question is where can i find a new gasket for the tb cover,
comment and thoughts appreciated, thanks ryan
Matt Monson
- quasi-mod-o
Be glad your engine is still stock and non-interference. I built an Ej20G/Ej22T hybrid for a guy a few years back and he did the same thing with the upper gasket on the cover. It got sucked into the DS cam gear, skipped his timing about 10 degrees and the engine ate itself. Snapped off two intake valve on one cylinder and banged them into the piston on the other.
You should be able to just take it all apart and put it back together again. Any dealer with have the gasket and at least here in Colorado, everytime I've needed one, Napa has had them in stock.
2000 2.5RS daily driver.
1999 2.5RS w/ 50+ extra whp
Suby Hai!
Suby Hai!
thanks, i'll check it out, my old man thinks i might have stretched the belt, any thoughts on replacing it, i bought the best highest priced one i could find.
belt went back on fine, cant find a tb cover gasket, anybody know a part #?
also my belt moves while running towards back then front, back then front like something is not allighned, any ideas???
you mean an accessory belt wobbles? Or the timing belt...
The crank pulley on these cars are notorious for coming apart (some two-piece design, the rubber cush between them weakens and it starts to wobble).
Or, the crank is bent, bearing hogged out.... something
12 Outback 3.6R Limited
94 Leg LS wag AWD, sold
93 Leg L wag FWD, sold
06 LGT 5EAT, project
my timing belt has a wobble, you can already see wear marks on the cam sprockets cause the belt, could it be a tensioner or something?
thanks Ryan
thanks Ryan
Something's very likely warped or a thrust bearing is gone. Watch it while it's running and it should become apparent which potential problem is the culprit. You might have to operate the throttle a little while you're looking.
thanks, i thinkn i better pull it all apart for the 5th time again this weekend, i'm gettin good at it at least, i'll get back to ya
i didnt round the key, but i did take the car to my mechanic and he said that it's okay to wobble or walk a little but he recommended changing my water pump and my all my rollers, especially if you drive it hard. i think i will try these things and hopefully it works out, thanks for all your guys help, let me know if you have any more thoughts. thanks Ryan
