CAI
Posted: Sun Jul 27, 2008 11:47 pm
by 94SS_Canada
ya ya, i know, But i need All the room in the world for my FMIC.
Is there any intake that we can use for out T-legs that can simply be bought?
Im running diffrent heads than stock so ther is a few less air lines than stock but what out there is a direct fit/ close fit?
Posted: Mon Jul 28, 2008 12:54 am
by know1
I am pretty sure anything off the shelf would be meant to go under your intake manifold. You said you are running different heads so I presume you are running a different intake manifold. If this is so and you have enough room to run a pipe under your manifold then you should be able to buy any wrx turbo inlet/intake pipe.
Posted: Mon Jul 28, 2008 5:31 pm
by RJ93SS
subarugenuineparts.com
Posted: Mon Jul 28, 2008 7:34 pm
by 94SS_Canada
Yes the heads and specifically maifold i am running allows more clearance for an intake but no enough to go underneath, i check out geniune parts, thanks
Posted: Mon Jul 28, 2008 8:15 pm
by 94SS_Canada
RJ93SS wrote:subarugenuineparts.com
Just went there, couldnt find anything?
Posted: Mon Jul 28, 2008 9:51 pm
by RJ93SS
it's called the spt turbo legacy cold air intake, it wont be a bolt up but it wouldn't take much to make it work for ya!
Posted: Tue Jul 29, 2008 1:22 am
by know1
would this be the spt intake for the new legacy turbos?
I was looking at it, it doesn't look to tough to fit.
Posted: Tue Jul 29, 2008 7:10 am
by 94SS_Canada
what about FMIC piping?
is it a short ram?
Posted: Tue Jul 29, 2008 5:25 pm
by RJ93SS
i think it's a bit of a short ram, basically it's just a starter for designing your own intake, what i will be doing after my td04 goes in is designing an intake from a cold air source with minimal elbows and long big straight pieces of pipe, if you dont know how to weld you could use silicone 90's or desighn something from pipe and tape the gaps and take it to somebody else to weld.
when i finish mine...one day.... i'll post up my desighn and results for the site
Posted: Tue Jul 29, 2008 5:55 pm
by 94SS_Canada
okay, i forget where all the air returns go now though
Does somebody have a diagram for all those intake air hoses?
Posted: Wed Jul 30, 2008 9:33 pm
by 94SS_Canada
