Deleting ABS ???
Posted: Sat Aug 02, 2008 11:25 pm
by Boostedballs
I am compiling parts for my water-to-air intercooler setup and I would like to place the shurflo pump in the spot where the battery goes or where the ABS system is.
I can move the battery to the trunk but I don't want to. OR I can remove the ABS.
What all is needed to remove the ABS and have the brakes function like normal?
Posted: Sun Aug 03, 2008 11:23 pm
by g20sleeperjdm
relocate the battery.. its much easier and i'd think cheaper too
Posted: Mon Aug 04, 2008 3:58 am
Put the pump under the battery, like what I did, or put it under the abs pump.
Having the pump at a low spot is a good idea.
Posted: Mon Aug 04, 2008 4:43 pm
by 93forestpearl
Removing the ABS requires making a bunch of brake lines. You need to be handy with a flaring tool, and making double flared ends.
Posted: Tue Aug 05, 2008 1:05 am
by Boostedballs
ok, I decided to put the cooler and fan under the battery and the pump under the ABS unit. I had a bunch of aluminum sheet metal laying around so now it is going to good use. I'll get some photos posted when it's all done.
