Abs 5.3
Kay95
Abs 5.3
Post by Kay95 »
I have the ABS light on in my 96 outback. Now I tried removing the relays and the light was still on like the FSM says. I also tried getting a code from it and dont know what the correct connector is to ground to get the code pulled. I also havent tried removing the control unit to see if the light goes out.
Any help from someone who has worked on one before?
