past problems i've had with 90 legacy, whining, dying
Posted: Mon Aug 04, 2008 11:14 pm
by farin3
quiet clicking on slow speed coast, and whining only on throttle, higher pitch with tire speed, kinda like revese whine, only happened over 15 mph on up.
Tried replacing rear exstention case, gears, clutches, no change, so replaced whole trans, problem fixed. think a gear out of line maybe planatary. gonna rebuild and find out,
seeing how well it was working.
after trans install, car started and died after 5 seconds or so.
ran with 1/2 throttle then died again. seems i missed a vacuum line,"the largest one" under air cleaner tube.
