'02 WRX clutch into '89 JDM turbo?
Posted: Fri Aug 08, 2008 1:22 am
by fngearhead
I've searched but can't find a definitive answer. I'm looking at a Spec Stage 1 kit with organic disc. The part number is the same for '02 WRX as well as '91 SS. I've found the WRX kit cheaper on a site that doesn't list anything for old Legacy. I'm hoping there aren't any differences between '89 JDM and '91 US turbo trannies as far as clutch and flywheel goes.
Posted: Fri Aug 08, 2008 3:15 am
by stipro
If you are going to use the wrx clutch setup you need the wrx flywheel.
