adding STI 6 speed to the old legacys
Posted: Wed Aug 20, 2008 5:59 am
by mellow65
i did find the nice read about the guy that swapped a sti 6 speed into his legacy turbo, but i still ended up with a couple questions that went unanswered.
1. the sti trannys required the "male" type of axles but they talk of just using legacy automatic axles. are the auto axle like the manual axles being the "female" type or do they share the same "male" style as the sti.
and if they aren't the "male" type, how do you get the axles to work with the sti tranny.
2. what clutch/flywheel set up do you use? do you have to use the sti or can you use a wrx or even the legacy turbo set up? and then use the corresponding starter because i think the sti one was bigger flywheel.
i know i had more questions, but i have spaced on them right now.
i'll add if i remember.
Posted: Wed Aug 20, 2008 6:38 am
by 93forestpearl
This has been hashed out many times. Nasioc is your friend. But I digress...
For 6mt:
Unless its an earlier '04 tranny, you need stub axles
auto driveshaft
6mt shift linkage
6mt tranny mount
6mt clutch/flywheel
newer starter or lots of grinding on the old one
unless you don't mind an open center diff, a controller of some sort (Spiider, Neetronics, etc.)
thats it for the important stuff. There are a couple other little details too, but that can wait
