Prevent bumper discoloration / melting?
Posted: Tue Aug 26, 2008 7:46 pm
by BSOD2600
After having my custom 3" exhaust on the car for a while, I've started to notice some discoloration of the bumper around the muffler. Specifically a light brownish color. For the most part it seems to come off with some rubbing (as seen in the pics), but I'm starting to worry that over time it'll become permanent.
Is there anything one can put on the area of the bumper to tastefully correct the issue?
Posted: Tue Aug 26, 2008 8:00 pm
by Dr. Gonzo
I've seen some bumper heat sheilds on ebay that I"m checking out for the same reason (except my tip is a little closer than your)
Here's link:
http://motors.shop.ebay.com/_Car-Truck- ... 1QQ_ptasZ1
Or you could always make your own...
Posted: Tue Aug 26, 2008 8:46 pm
by 93forestpearl
A little carb cleaner will take it right off. Careful, because if you too far with it, your paint will be gone too.
Posted: Wed Aug 27, 2008 1:01 am
by RJ93SS
glue on a small piece of white leather, i actully melted my bumper but it was touching the body for 3 months, it doesnt help that your car is white either. try a leather welding glove.
Posted: Wed Aug 27, 2008 4:34 am
by 94SS_Canada
Extend your Exhaust, duh.
Posted: Wed Aug 27, 2008 7:03 am
by BSOD2600
94SS_Canada wrote:Extend your Exhaust, duh.
Yea, well I bought it the customed fabbed exhaust from another board member, so didn't have any of the work done myself (besides its installation), otherwise I would've made sure the tip was longer.
I suppose I could have the muffer tip extended 1".... wonder what that "simple" thing would cost me.
Posted: Wed Aug 27, 2008 10:06 pm
by asc_up
+1 on extending the exhaust. A shop could do it in 10 minutes and it wouldn't cost much at all, plus you won't have that problem anymore.
Posted: Thu Aug 28, 2008 1:28 am
by SubaruNation
maybe keep it sprayed constantly with some kind of oil that would stay there and collect that buildup?
wd40 or silicon or something?
like put a wee bit of something that you could wipe off but would stay there until you wanted to take it off.
teh extention is a better idea, or you could even do a reduction in length.
Posted: Wed Sep 03, 2008 4:53 am
by RJ93SS
after seeing those pics, i would cut that tip down to about an inch,
and find a piece of polished stainless with an i.d close to your existing pipes o.d and screw the stainless into the 1 inch remaining, it would look like a fresh tip and you could make it as long as you want.
Posted: Tue Sep 09, 2008 11:09 pm
by supra90turbo
I'm with RJ93SS. Not to mention stainless would look great and stay looking great.
That
will permanently stain if you don't keep cleaning it. There aren't any solutions to prevent it from happening that will be low profile, just something like this:
or this: Big picture warning!!
http://www.jjlcustoms.com/FIL2527.JPG
and here's a writeup on how to do it, only you should do it good, not like the guy on the site did.
